Rear 1/4 Windows Stay Up
Old Nov 17, 2022 | 08:29 PM
erjent's Avatar
Default Rear 1/4 Windows Stay Up
On my new 2000 XK8 the rear 1/4 windows stay up when the roof is opening. I've checked Fuses 5, 12, and 20 in the rear fuse box. I'm guessing it could be a relay or switch, but I have no idea where they would be located. Can I manually test the windows? I replaced the battery, and reset the window positions. I assume this was happening before I bought the car.
Much thanks,
Eric "erjent" Jordan
Old Nov 18, 2022 | 09:18 AM
motorcarman's Avatar
The quarter window relays (there are 2 each window) are in the boot in the fuse/relay box.
The Electrical Guide has location and operation info. (S2000_XK8.pdf)
One changes state while the other stays to move open or closed.(5 terminal SPDT)
Check relays and power/ground at the terminals?
File Type: pdf
Old Nov 18, 2022 | 10:22 AM
rod9669's Avatar
Has anyone added a switch to control them separately? Anything that doesn't look standard anywhere, in particular the centre arm rest cubby hole?
Old Nov 18, 2022 | 12:16 PM
Have a look here:- https://www.jaguarforums.com/forum/x...op-down-37826/
And here :-
Old Dec 19, 2022 | 05:24 PM
oldjaglover's Avatar
The video you posted showing how to bypass the relays to get the rear windows to raise or lower has disappeared. Something with U-tube. Can you reset that video??
I can't get my rear windows to go up after lowering the top and getting it back up. It was hard raising so I had to hold the button for a long, long time. Top is up and finally latched, but rear windows are stuck down.
Ken K
Old Dec 19, 2022 | 06:17 PM
OK. I got the video again and watched it 4 times. But the author's hands block too much of what he is ding to see. Can you explain which connectors/wires/relays he is "jumping" or attaching to? Is there power from the battery involved, or just getting one part of each relay to activate?
Ken
Old Dec 20, 2022 | 02:53 AM
DavidYau's Avatar
Default Small Relay dis-assembled
Maybe this pic will help you. The big top pin is for the +ve power. I did this job a while ago (built a switched relay), so can't remember which position was up/down. You can experiment without breaking anything.
Sorry I couldn't remember any more.
larueb
Aug 9, 2022 04:32 PM
MrSinatra
Feb 4, 2022 08:01 PM
steve massey
Jan 24, 2021 04:38 PM
Kenny Locke
Jul 7, 2019 02:00 PM
Stamford
Jul 28, 2017 09:34 AM
