rear anti roll bar link
Old Jul 28, 2012 | 09:14 AM
dennisw's Avatar
Thumbs up rear anti roll bar link
planning to replace the rear anti roll bar links..sway bar..on my xkr next week..looks a diyself job..but any advice would be good.
thanks...
Old Jul 28, 2012 | 11:39 AM
ccfulton's Avatar
It isn't too difficult but you will be way under the car and there isn't much elbow room if it isn't on a lift.
The bolts are out in the weather so some WD40 or other loosening agent is good to have. Also a god size adjustable wrench to slip over the flat part of the link and keep it from twisting the rubber while you tighten the nuts.
If you haven't got them already it is a good time to replace the end link bushes, or rubbers as they are sometimes called. The link doesn't usually come with them but there are two for each side.
Old Jul 28, 2012 | 12:00 PM
Goldlion's Avatar
As advised the bar, links and bolts are easy to get at. This is really a snap to do if you are on a lift. For sure, apply WD40 or a good penetrating oil a day or two in advance and it will make bolt/nut removal much easier. When I replaced these items on my 2005 XKR Coupe I went with PowerFlex poly bushings and have been quite pleased with the results. While you are doing this work you may want to check on the condition of the lower strut bushings and the sub frame/beam bushings for signs of deterioration. In addition, if the grease fittings for the differential/drive axels have not been recently serviced you may also want to apply grease accordingly.
Old Jul 29, 2012 | 04:30 AM
smoggyx100's Avatar
I did these last sunday, on my drive. When putting it back togeather you just need to jack up the suspension a bit to get the bottom nut on.
Old Jul 29, 2012 | 06:30 AM
dennisw's Avatar
thanks to all for advice..spanner ready for action
Old Jul 31, 2012 | 01:05 PM
dennisw's Avatar
My new links arrived today but the rubbers are not the same..the metal link washer and nut are exactly the same but the old one has 2 rubber washers ..on goes above and one goes below ..but the new one has only one rubber..looks like a moter bike suspention cover..please see pictures..advice needed..one of the washer is still on the old unit and one washer is missing ..still on the car
Attached Thumbnails rear anti roll bar link-img_0619.jpg   rear anti roll bar link-img_0620.jpg   rear anti roll bar link-img_0621.jpg
Old Jul 31, 2012 | 01:20 PM
ccfulton's Avatar
It almost looks as if the new one is both rubber washers made in a single mold. Could it be a manufacturing defect and they forgot to cut them apart?
Is there any instruction about cutting them apart before installing?
Old Jul 31, 2012 | 01:29 PM
dennisw's Avatar
this is exactly what i thought..no instructions inc..i think ill go for cutting the rubbers..thanks for your reply
Dennis
Old Oct 4, 2012 | 06:36 AM
dennisw's Avatar
Smile
Originally Posted by felipe
I guess you are misled by some one otherwise replacing the rear anti roll bar link is not difficult. You keep working on it and then share your experience.
thanks for your coments..it is a very easy job
Dennis
Old Oct 4, 2012 | 08:28 AM
rocklandjag's Avatar
My new links also came with only the single mold. I cut them in 1/2 adn installed them. No squeaks or clunks
Old Oct 4, 2012 | 09:05 AM
dennisw's Avatar
same here..im happy
Old May 30, 2013 | 12:22 PM
smoggyx100's Avatar
Dear all
Just for information these bottom bushes (that had to be cut apart) disintegrated on my car. In fact one went AWOL in less than 6 months.
I have now replaced then with jaguar ones. Which are far stiffer and more substantial.
regards
FrickenJag
Jun 16, 2025 02:15 PM
aholbro1
Dec 29, 2024 06:46 PM
H20boy
Dec 24, 2024 03:23 PM
carcycle
Sep 7, 2015 10:22 AM
Joey T
Sep 3, 2015 05:31 PM
