Rear hub frozen to axle shaft - help
Old Dec 7, 2018 | 11:05 AM
Rabs's Avatar
Default Rear hub frozen to axle shaft - help
I am in the process of removing the rear hub as I plan to replace the rear wheel bearing. I have the handbrake disconnected, have removed the Caliper, the axle nut is removed and I have taken out the pivot pin as per the guide I found on the forum and from reviewing the manual.
All found in this link https://www.jaguarforums.com/forum/x...nstall-189458/
The issue is that the hub is stuck to the axle shaft. I imagine it’s rusted to the hub as they seem to be different metals. Can someone confirm that I am not missing anything? Based on the above it should just come off th axle shaft, is that correct? I have tried some heat and also a lump hammer but before I go crazy on it I just wanted to check. Thanks for your help in advance.
Old Dec 7, 2018 | 12:54 PM
Johnken's Avatar
Wow that's a good one. The hubs have always just dropped off for me. I bet the bearings are binding it up.
wish I had a sure fire answer for you, but let's think about it. I once stopped to help a lady change her tire. Took the lugs off - it was frozen! The tow truck guy showed me the answer. He sat down facing it, than kicked the left right left side of the tire. Sure enough it popped free.
can you build off that...the studs are still there right? I'm not sure you could safely reattach the wheel (it'd sure give you some leverage to whack against wouldn't it?). Could you drill a few holes in a 2x6, attach it to the studs with the lugs and use it to rock / lever / hammer the unit free?
guess I'm trying to think of ways to give you a good striking surface or leverage to work it free.
if this won't work, I hope it gets folks creativity going.
John
Old Dec 7, 2018 | 01:25 PM
StuG's Avatar
You need to beg, borrow or steal a rear hub puller.
https://www.scparts.co.uk/sc_en/puller-1-44324.html
Old Dec 7, 2018 | 02:34 PM
motorcarman's Avatar
I use a slide hammer for stubborn flanges.
Here is a tip for a common setup.
I use a set like this.
You might try some penetrating oil in the splined area.
bob
Post Script.........
I leave the lower fulcrum shaft in place and repair the hub still attached to the car. That way you leave the rear 'toe-adjustment' alone.
Old Dec 7, 2018 | 10:41 PM
zray's Avatar
I would spray the joined area with a full can of CRC Freeze Off. That stuff is marvelous for freeing disc brake rotors that are frozen / corroded on the hubs..
Z
Old Dec 8, 2018 | 02:34 PM
StuG's Avatar
When I had to pull the hubs off my 55 year old MK2 in order to install wire wheels, the fronts came off easily but the rears would not budge. I was able to borrow a hub puller from another jaguarforums.com member in Australia which made the job easy as pie. I know that the Jaguar Club of North America has a variety of specialised tools which it loans to its members (doesn't really help you or me). So, you should try contacting your local UK club/s and ask if anyone has a hub puller you can borrow.
Old Dec 8, 2018 | 02:47 PM
Rabs's Avatar
Thanks for all the comments, I sprayed lots of penetrating fluid and left it to soak, still wouldn’t budge. Then hit it with a MAPP torch to give it some heat and used the lump hammer. Finally got it off
Old Dec 8, 2018 | 04:05 PM
RJ237's Avatar
The MAPP is a great tool.
Old Dec 9, 2018 | 04:28 AM
Rabs's Avatar
Have it all apart now and the races off, just need to get the new bearings pressed back on. I have noticed on the half shaft that there is play as per the video link below. Is this normal? I would imagine it is as just the play in differential.
orangeblossom
Jul 19, 2018 04:15 PM
innzane
Oct 24, 2017 04:04 PM
andrew lowe
Nov 26, 2014 05:49 PM
penguin
Mar 18, 2013 12:10 PM
AML
Jun 9, 2011 07:32 AM
