Rear Sub Frame Grit Trap
Old Jan 30, 2016 | 06:02 PM
64vette's Avatar
Default Rear Sub Frame Grit Trap
Cleaning up the undercarriage which I like to do on occasion on my cars as it is a good chance to check for loose hardware, missing fasteners or any other odd potential problems. In doing so on my XK8 I discovered a fair amount of dirt and tar coated road gravel which makes it stick trapped in and on the rear subframe. I would say enough to fill a cigar box from the sub-frame flanges and upper surface. Took about a half hour to get it off the flanges and out of the nooks and crannies. I would think where you have road salt and slush to deal with this would be a nice source of corrosion, and might warrant some attention to keep cleaned out.
Old Jan 31, 2016 | 03:43 AM
RaceDiagnostics's Avatar
I'm on the lookout for a good replacement as they tend to rust from the inside out in the UK.
Old Feb 3, 2016 | 08:27 AM
malbec's Avatar
I looked under my girls' skirt
12 years old, a bad thing to do.
Old Feb 3, 2016 | 08:59 AM
daro31's Avatar
I just dropped the rear sub-frame of my 2004 XK8 Monday night and got it stripped down last night. It looked almost as good as yours from below but I was suspiscous of all those places I couldn't see. As you say they look like grit traps. I had nothing wrong with the rear end except it is a twelve year old canadian car, and I figured shocks and bushings are probably due. The attached picture will tell the tale. Parts in for blasting this morning, then I will repair that front rail and get it all powder coated. I am going to put a sealant of some kind between the subframe and the vertical triangle shaped piece when it goes back together.
Old Feb 3, 2016 | 09:33 PM
White Bear's Avatar
Melbec,
Are you aware that repair panels are available in the U.K. for just your problem?
I used one and it fit really well and is lot cheaper than replacing the whole sill.
Jaguar XK8 XKR (X100) Body Repair Panels Rear Half of Sill | Jaguar XK8 and XKR Parts and Accessories
Old Feb 3, 2016 | 10:17 PM
plums's Avatar
I'm partial to just good old fashioned oil spray.
But you might like one of the new seam sealers.
From 3M I think?
Old Feb 3, 2016 | 10:18 PM
plums's Avatar
How very rude!
Old Feb 4, 2016 | 02:46 AM
malbec's Avatar
Originally Posted by White Bear
Melbec,
Thanks, I have left the car with repair people but have sent them your link.
Many thanks.
Old Feb 4, 2016 | 03:30 AM
johns55's Avatar
And another rusted mess. I bought another a frame from a junk yard.
Old Feb 4, 2016 | 09:41 AM
64vette's Avatar
From 3M I think?
This is by far the best product I have found for internal cavity rust stop and rust proofing. Just be careful to protect any surfaces where you don't want it, it is nearly impossible to remove. I think some strategically drilled holes in the sub-frame would allow access and it would be nice to somehow get a borescope in there first to see what is going on internally.
Eastwood Internal Frame Coating 14oz Aerosol
noterman
Feb 4, 2016 12:25 AM
lsbrodsky
Jan 31, 2016 02:18 PM
mikerossi395
Jan 28, 2016 07:01 PM
xxxscimitarxxx
Jan 27, 2016 10:51 AM
stephensd1
Jan 26, 2016 03:10 AM
