Rear Sway Bar Insulators
Old Jul 19, 2021 | 03:51 PM
XK8 Comfort's Avatar
Default Rear Sway Bar Insulators
I am ready to replace the rear Sway Bar Insulators on my XK8 and I would like to know if the rubber cushion should be on the top or the bottom of the sway bar mount. Here is a picture.
Old Jul 19, 2021 | 06:19 PM
cjd777's Avatar
They go on just like you show them, but if in doubt, have a look at this add for the system.
https://www.ebay.com/itm/28404660273...aaf9f3619bdf0d
Wayne
Old Jul 19, 2021 | 07:37 PM
My question is does the rubber stack go on the upper side or the lower?
Old Jul 19, 2021 | 08:45 PM
baxtor's Avatar
that looks like an aftermarket bushing type. You need to feed the bushing through the mount hole on lower suspension arm so that it engages the central slot in rubber. Then feed link through.
Old Jul 19, 2021 | 09:15 PM
cjd777's Avatar
The rubbers go one on each side of the lower hole, the right angle end goes into the sway bar with the nut on the inside of the bar.
Old Jul 19, 2021 | 09:50 PM
tjankovs's Avatar
I could not get mine to fit so I sawed them in half. Half on top, half on the bottom. Worked fine for 3 years now.
TJ
Old Jul 20, 2021 | 08:01 AM
PKWise's Avatar
Yeah, as cjd777 states, it's top and bottom.
You can upgrade with powerflex bushes and they are also top and bottom.
Old Jul 20, 2021 | 08:59 AM
Johnken's Avatar
Kent, check this out. The Energy bushings last far longer than the polyflex.
https://www.jaguarforums.com/forum/x...ight=Rear+bush
John
Old Jul 20, 2021 | 09:04 AM
Johnken's Avatar
Just did a quick check for you and for anyone:
$4.00 at Summit.
https://www.summitracing.com/parts/e...waAoFKEALw_wcB
John
Old Jul 20, 2021 | 05:49 PM
giandanielxk8's Avatar
$4.00 at Summit.
John
10,000 miles and 2 years later, I can confirm that they are still going strong.
Old Jul 20, 2021 | 07:08 PM
STLTHMSTA's Avatar
$4.00 at Summit.
John
Thanks, I just ordered some and some upper bushings for my daily driver. TM
Old Jul 20, 2021 | 09:36 PM
Johnken's Avatar
You'll be smiling soon Tom!
John
Old Jul 20, 2021 | 11:11 PM
You will have to trim them down a bit.
Old Jul 21, 2021 | 06:01 AM
STLTHMSTA's Avatar
We'll see. Not sure of the condition of mine but for that price I'll keep them on hand at the very least. They have shipped already and will be here tomorrow. Summit is just over 100 miles from me. Again that's for the info. BTW, the upper bushings of my daily driver were shown at the bottom of the listing online. Karma? Fate? Not very much so I bought them too. TM
al_roethlisberger
May 25, 2017 07:05 PM
weisberg
Jul 20, 2014 11:34 AM
ez53436
Jul 10, 2013 10:19 PM
Ahiman
Jun 3, 2013 04:31 PM
GordoCatCar
Apr 24, 2013 12:34 PM
