Remanufactured alternators... which one?
Old Jan 31, 2023 | 08:14 AM
szhilian39's Avatar
Default Remanufactured alternators... which one?
Hi,
Since I am doing a major cooling system overhaul, I already took out many parts such as fan assembly, belts, pulleys, hoses, etc.
After visually inspecting the alternator (looks so nasty) I decided to replace it with a remanufactured unit.
I found several remanufactured units on Rockauto and the price range is $95-$170.
My question is... which one? does the expensive one is better than the others? Can anyone recommend a remanufactured unit for my 2006 XKR?
Thanks in advance,
JW
Old Jan 31, 2023 | 09:25 AM
Pistnbroke's Avatar
I found a new one from Denso was the cheapest option on ebay at about $140.
Re manufactured can mean we fit new Diodes /regulator .slip rings and brushes along with bearings or it can mean we just sandblast as much of the old as we can leave in the old bearings skim the slip rings and fit new brushes. Give it a 90 day warrantee and if it fails give you another.
You dont need the 220A but you need a pulley as they are a pig to tighten.
Old Jan 31, 2023 | 09:37 AM
giandanielxk8's Avatar
Go have yours rebuilt with denso original parts.
Old Jan 31, 2023 | 10:08 AM
Jon89's Avatar
^^ This. And take it to a long-time-in-business, well-respected shop....
Old Jan 31, 2023 | 10:32 AM
xalty's Avatar
local reman, denso, or used
otherwise you will be back on here crying and asking “why doesn’t my chinese regulator work like a real one 😢”
Old Feb 1, 2023 | 09:06 AM
szhilian39's Avatar
[UPDATE]
As suggested, I found 2 decent local remanufacturers in my town. I will contact them to make sure they use original Denso parts.
Thanks for your suggestions.
JW
giandanielxk8
Oct 13, 2022 07:44 PM
retroren
Jul 16, 2021 09:55 AM
jagstuart
Feb 24, 2019 04:30 PM
JigJag
Jun 19, 2017 05:21 AM
baldeagle15
Nov 13, 2015 01:36 PM
