srs block
Old May 15, 2020 | 03:04 AM
ruslan68tmb's Avatar
Default srs block
hello everyone, where is the srs block?
Old May 15, 2020 | 03:57 AM
Welcome to the forums ruslan68mb,
Do you mean the SRS (Supplementary Restraint System) Module? Also please add vehicle Model and Year details.
Old May 15, 2020 | 04:16 AM
yes, srs module, jaguar XK8 x100 2003. Some say 2 modules are installed. I don't know if this is true or not
Old May 15, 2020 | 04:47 AM
SRS is complex. This diagram from JTIS (Jaguar Technical Information System) is the easiest explanation of the system:
Here is the module under the centre console cubby box liner on my 2005 XK8:
Good luck - SRS faults can be difficult to troubleshoot.
Old May 15, 2020 | 05:16 AM
why 2 modules: 12 and 17?
Old May 15, 2020 | 05:25 AM
bladerunner919's Avatar
Perhaps if you tell us what problem you have, we can help?
Old May 15, 2020 | 05:36 AM
Why is there 2 blocks in the car? one in the center, the second at the right stand
Old May 15, 2020 | 05:47 AM
Because they do different things. One controls the airbags,and one controls the restraints (seatbelts). That doesn't actually answer the question about what problem you are having.
Old May 15, 2020 | 06:31 AM
I have such security errors. I want to remove the module to reflash it
Old May 15, 2020 | 07:18 AM
Reflashing is the nuclear option!
B2291: OPS Sensor Fault
B2292: Pretensioner Circuit Front - Open Circuit
B2295: Air Bag Side - Open Circuit
With each of these, the PID code will indicate which sensor or which side (driver or passenger). The DTC combination suggests harness damage or faulty harness connectors.
Old May 15, 2020 | 07:31 AM
car after an accident.
Old May 15, 2020 | 07:46 AM
crbass's Avatar
Have the belt pretensioners and the airbags been fired?
Old May 15, 2020 | 07:52 AM
It's always the details that make the difference.
As asked by crbass above - fired (?) and if so, additional damage to the vehicle makes a big difference to the diagnosis, testing and repair.
Old May 17, 2020 | 10:01 AM
JagV8's Avatar
Doesn't sound like reflashing is worthwhile.
Old May 17, 2020 | 11:31 AM
motorcarman's Avatar
Some modules can be used several times. There is a way to determine which modules and how many times but I forget all the details.(been too long since I worked at the dealer)
Here is a TSB with info that might help.
bob
File Type: pdf
Old May 18, 2020 | 06:24 AM
Thank you all, found and reflashed the module
Unhingd
Feb 26, 2019 12:01 AM
muckbury
Nov 3, 2013 09:20 AM
mcwulf30
XJ40 ( XJ81 )
Jul 20, 2012 12:49 PM
pdowning6
Mar 23, 2010 11:32 PM
