Ticking Sound from Front Left Wheel Well
Old Apr 10, 2011 | 12:25 AM
Reverend Sam's Avatar
Default Ticking Sound from Front Left Wheel Well
I noticed the other day that I have a pretty loud ticking sound from the front left wheel well. I noticed it when I was sitting in the driveway and opened the driver's door. I can't hear it when the door is closed. I revved the engine but the ticking sound didn't change speed. It's about 3 or 4 ticks per second. I seem to remember a thread about this from many months ago, but I don't remember the cause and I can't find the thread. Any thoughts?
Old Apr 10, 2011 | 12:29 AM
H20boy's Avatar
Rev, purge valve, ticking and fuel smell...i started the thread, search for me. TSB fixed it w new part. Mobile now or else i'd find it for you.
Old Apr 10, 2011 | 12:30 AM
Thanks. I found your thread. I have no gas smell, though.
Old Apr 10, 2011 | 01:06 AM
H20boy's Avatar
I didnt for years either. Driving slow is where that happens.
Old Apr 10, 2011 | 03:35 AM
Frog's Avatar
I have a similar ticking when starting off (no fuel smell, though). I assumed it was the CATS suspension fine tuning the ride..?
Old Apr 10, 2011 | 07:46 AM
WhiteXKR's Avatar
Some ticking from the purge valve is normal.
The purge valve is 'shock mounted' in rubber mounts to minimize transfer of noise to the vehicle. If it is really loud, you might want to remove the left wheel and wheel well liner and double check that it is still 'floating' in its mount and not contacting anything that might transfer the sound.
The TSB replaces the valve with a new design that includes a filtered vacuum intake, remoted via a hose to the brake booster enclosure. I am not really sure if the new design is quieter, only that it has changed in response to the fact that the old one corroded internally, eventually causing the fuel odor issue.
Old Apr 10, 2011 | 12:01 PM
H20boy's Avatar
The new one I replaced it with is 100% quiet, worth the $70 n vry easy to DIY.
Old Apr 10, 2011 | 04:01 PM
WhiteXKR's Avatar
WIth my high flow cats and Mina exhaust I would never know
SD96XJ6L
Jan 12, 2022 04:30 AM
mhamilton
Sep 15, 2015 05:13 PM
tberg
Sep 7, 2015 07:32 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
timm525
Aug 29, 2015 04:49 PM
