top operation
Old Jul 1, 2014 | 11:33 AM
magnum454's Avatar
Question top operation
On my 2000XK8 convertable, the key in the door lock does not operate the top. I turn it counter clockwise and nothing. Is this a common problem?
Old Jul 1, 2014 | 11:36 AM
WhiteXKR's Avatar
You need to turn it quite hard past the stop and hold it, (it is spring loaded). Are you sure you are turning it hard enough?
Old Jul 1, 2014 | 11:38 AM
You have to hold in the counterclockwise position during the open operation. mine takes a few seconds before it starts to engage - maybe 5 or so.
Old Jul 1, 2014 | 11:39 AM
magnum454's Avatar
I am turning it pretty hard but maybe not holding it long enough. How long should I hold in this position?
Old Jul 1, 2014 | 11:42 AM
magnum454's Avatar
Thank you. I'll try it again. Also, does it work for putting the top up?
WhiteXKR's Avatar
You need to hold it under tension through the entire cycle, just like the console button.
One of the advantages of the Remote Top that I sell is it is two touches on the remote and then you do not need to hold the buttons.
Old Jul 1, 2014 | 11:44 AM
Yes works for up operation as well just in clockwise direction
Or you can use whitexkr's remote which several folks have added with great results
Old Jul 1, 2014 | 02:06 PM
brgjag's Avatar
Remote?? Can I get this for my 03???
Old Jul 1, 2014 | 02:07 PM
brgjag's Avatar
Side note on this action. Isn't it hard on the battery to put it up and down with out the car on????
Old Jul 1, 2014 | 02:11 PM
Brgjag
I believe so - check out jag wranglers website in post 2 of this thread
Old Jul 1, 2014 | 02:22 PM
WhiteXKR's Avatar
Yes, it is compatible with your '03 convertible.
It will draw about 0.20% (one fifth of 1%) of the battery charge for each top cycle. That is not enough to have any meaningful effect on the battery life. The unit itself draws virtually zero standby power (a few millionths of an amp).
There are now hundreds in use and no reported issues once properly installed.
aholbro1
Dec 29, 2024 06:46 PM
Rivguy
Nov 13, 2022 02:55 AM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
mrplow58
Sep 9, 2015 11:27 AM
1100me
Sep 7, 2015 06:26 AM
