Using a battery tender for my xk8
Old Feb 13, 2014 | 03:24 PM
kelliott's Avatar
Default Using a battery tender for my xk8
I just purchased a 2004 xk8 conv. I want to use a trickle charge unit on the battery. how do I get the lights in the trunk to go off so I won't drain the battery at the same time I'm trying to maintain the charge.
Old Feb 13, 2014 | 03:44 PM
richzak's Avatar
Spend some time reviewing this thread:
https://www.jaguarforums.com/forum/x...lation-107738/
Old Feb 13, 2014 | 05:00 PM
test point's Avatar
Connect the charger under the hood to the fuse panel feeds
Compliments of Paul Pavlik
Old Feb 13, 2014 | 05:08 PM
K.Westra's Avatar
I connect mine in trunk and the lid goes down low enough to turn the lights off. They should turn off in time, even if the lid isn't low enough, though.
Old Feb 13, 2014 | 05:39 PM
Originally Posted by K.Westra
I connect mine in trunk and the lid goes down low enough to turn the lights off. .......
+1
I did the same with my two XK8's.
Some members have left their phone inside recording a video clip to prove the light actually does go off when you put the lid down without closing it fully.
I thought it was much more fun to persuade my wife to climb inside and watch. If your face even starts to crack a smile in the next 24 hours after that, you're lost.
Old Feb 16, 2014 | 03:01 PM
stevepaa's Avatar
I just close the trunk on the thinner leads, leave the charger sitting outside of the car
Old Feb 16, 2014 | 03:32 PM
Cherry_560sel's Avatar
I just push the latching mechanism. That turns the power off to the light. Then I lower the trunk lightly. I unplug the trickle charger when I need the car and just leave it in the trunk and then hit the unlock button on the trunk lid then close the trunk.
Old Feb 16, 2014 | 04:33 PM
Norm 427's Avatar
LOL! I'm lost.
Up in Alaska I was told that the way some guys can tell if a woman is worth marrying is that they put their girlfriend and their dog in the trunk. After a while they open the trunk. If the woman is as happy to see them as the dog is, then she passes the test and is marriage material.
Old Feb 17, 2014 | 05:19 AM
smithtrevor's Avatar
Yep....did the wife bit...went for a cuppa....screamed at me for the next 3hrs, decided the only safe way was to take the lamps out!
Old Feb 17, 2014 | 10:09 AM
chopr's Avatar
I simply close the trunk lid. The weatherstrip is pliable enough to allow for the tender cord. Another option would be to "trip" the latch using a small screwdriver etc, mimicking a closure, which shuts the light off. Then you can leave the trunk lid open. Just don't forget to "open" the trunk latch before shutting the lid again!
Old Feb 17, 2014 | 04:45 PM
Paul Pavlik's Avatar
Other than keeping the Mice out, there is no need to close the Trunk (Boot) Lid completely during Storage when using a Battery Tender.
The lamps will extinguish after a short delay even if the Lid is Not Latched!
Old Feb 20, 2014 | 05:09 AM
The_Ikon's Avatar
Ha LOL!
99xk8guy
May 28, 2024 09:36 PM
picard
Oct 12, 2015 11:56 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
DuhCar
Sep 11, 2015 10:58 AM
DEklof
Sep 8, 2015 05:28 PM
