VVT seal leaking oil AGAIN!!!
Old Feb 20, 2013 | 11:30 AM
artstar's Avatar
Default VVT seal leaking oil AGAIN!!!
Hi, I replaced the VVT seals less than 3 months ago and it's leaking oil again. From what I can see it's only the drivers side one. I noticed the smoke from the oil driving this morning. Is there another problem that is causing this such as overpressure, etc? Anyone have suggestions to solve this once and for all?
Old Feb 20, 2013 | 11:37 AM
The Coupe's Avatar
In that spot, I wouldn't think it would be pressure related. Hmmm. We'll collectively think this one over and get back to you!
Old Feb 20, 2013 | 11:38 AM
test point's Avatar
Have you cleaned your part-load breather tube? Pretty small orifice but it does suck some pressure out of the driver side valve cover.
Old Feb 20, 2013 | 11:40 AM
WhiteXKR's Avatar
There is usually a lot of dirt, grit and sometomes corrosion on the exposed part of the solenoids. The seal can easiliy get contaminated when being replaced unless the area is throughly cleaned first.
Also make sure your valve cover breathers are not clogged causing excessive pressure.
Old Feb 20, 2013 | 11:46 AM
Jon89's Avatar
What causes the VVT seal to leak in the first place? They all seem to eventually. Is it heat, substandard materials, design flaw, internal pressure, all of the above, or what?
And what is the proper procedure for seal replacement?
Old Feb 20, 2013 | 11:59 AM
artstar's Avatar
Don't know what/where that is but I'll research it here and do that. Also I have to admit I didn't do a thorough cleaning job when I replaced it just popped off the old one and popped this one on really.
Old Feb 20, 2013 | 01:20 PM
Stumpy's Avatar
Old Feb 20, 2013 | 01:24 PM
WhiteXKR's Avatar
Since the seals are still new and pliable, try a thorough cleaning and refit them.
Old Feb 20, 2013 | 02:53 PM
artstar's Avatar
Hi, I'm trying to clean the breather line but in the pdf attached, from jagrepair.com btw, it shows a clip to take it off. Per my other pic mine doesn't have that. Is by hand possible or ok? That's the correct line right? It's kinda confusing from the pdf which side is which.
Old Feb 20, 2013 | 03:04 PM
Paul Pavlik's Avatar
On mine, the Clip was missing. You just have to squeeze the ring until the ring bows out to permit removal.
Old Feb 20, 2013 | 04:12 PM
artstar's Avatar
Can't get that thing off after trying for a while. I cleaned the VVT and seal and reinserted so I'll keep an eye on it. If it keeps leaking I'll get that breather line off somehow!
Old Feb 20, 2013 | 04:32 PM
Jag#4's Avatar
I couldn't get mine off either when I cleaned the throttle body, etc. After much squeezing and cussing, I remembered the many cautions about that plastic piece being brittle and easy to break, so I gave up. My clip was missing as well.
I would also be interested in any tips for doing this. It seems so simple, but so do many things I cannot do.
Old Feb 20, 2013 | 05:02 PM
steveeasy's Avatar
Hi,
had problem removeing mine as well. but they are so simple, look carefully at it with a torch, squeeze the ring gently but firmly, whilst pushing down and then up and the plug will just pull off.
Incidently my pipe broke nr the plug, it was very easy to repair. i removed the piece of pipe from the plug with a sharp blade, and then used hot water to fit the remaining pipe on to the plug.
Best wishes
Steveeasy
Old Feb 20, 2013 | 05:45 PM
artstar's Avatar
Originally Posted by steveeasy
Hi,
Best wishes
Steveeasy
Ok, so it's squeeze the RING not the handles attached to the ring?
And then push the ring down then up to clear the sleeve?
After driving around a bit it looks like the VVT seal is leaking since I cleaned everything so maybe this is the problem. Guess I could ask Motorcars Ltd for a replacement since I got it through them.
Old Feb 20, 2013 | 06:06 PM
Gus's Avatar
Gus
Looking at the illustration on the PDF you have it shows that you remove the hose by installing a clip but I am not sure you have one. Looking at your photo it looks like someone has been trying to remove it with a tool like a screwdriver. The clip in illustration 3 is separating the locking clip of the female fitting (top) from the male fitting (bottom) and sealing the connection is an “O” ring. To get this off you will need to use a little pulling force and at the same time squeezing the two sides to force the holding clips out and a little twist will help. One thing for sure excessive force will cause breakage.
Link from my page http://www.jagrepair.com/images/TSB/...20Breather.pdf
Old Feb 20, 2013 | 06:13 PM
artstar's Avatar
Yeah I got a bit frustrated and tried a screwdriver but thought better of it after it started breaking in places. I tried pliers on the handles attached to the ring and pulling up, no joy. I'll try just squeezing the RINGS not the handles etc next time I'm out there.
Old Feb 20, 2013 | 06:20 PM
test point's Avatar
The plastic connector is only held in place by the 'O' ring seal inside and the plastic retaining circlip. After understanding how the circlip is released try twisting and pulling.
Old Feb 20, 2013 | 06:56 PM
I believe that there are small tabs, facing inward, at the bottom of the Flat Sides of the Upper Connector. These tabs fit into slots in the base of the Lower mating Connector. These must be moved outward to release the Upper Connector.
As I recall, you squeeze the ring sides of the connector inward (Not the Flat Sides). This deforms the connector, forcing the Flat side tabs outward to clear the slot that they are in. This provides the same result as forcing the Clip (if present) inward does.
Then you twist back and forth and pull the connector off.
Old Feb 20, 2013 | 10:51 PM
mike66's Avatar
Just in case it goes horribly wrong......Jaguar Crankcase Breather Hose - Genuine Jaguar AJ8004880 | FCP Euro
On the picture you can see that pushing in the ring on the sides moves the locking tabs out and releases the hose.
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
kelliott
May 31, 2022 05:26 PM
Scarecrow
Mar 28, 2016 03:17 AM
Dymaxxion
Sep 4, 2015 02:40 PM
