Water pump xk8
Need to replace the waterpump on my 2001 xk8 have looked at Rockauto they have about 6 or 7 diff manufactures listed. What pump do you guys and Girls recommend ? Thanks in advance Peter
Metal impeller versions are NOT an upgrade, there is no upgrade to the current oem pump.
There are some cheap models on the market with metal impellers that are prone to leaking, reported here on the forum.
Also, our cars do not have silica in the coolant to protect metal impellers against cavitation, which plastic impellers don’t need.
The original plastic ones last very long, so that would still be my choice.
PS Only the very 1st plastic models from 97/98 where prone to failure...
That’s incorrect. One of the youngest 4.2 engines I have seen was built mid 2007, and had plastic impellers as used from the 1st 4.2 engines build.
Jaguar has never made a change to metal impellers; at least they have not made it known. All 4.2 engines I have seen have plastic impellers, and when you buy a new pump from Jaguar, you will get a plastic impeller.
So why do you think is metal?
chatmanx
Sep 11, 2015 07:17 PM
