What coolant?.
Old Nov 25, 2022 | 06:48 AM
Ant Buck's Avatar
Default What coolant?.
What is the best coolant you can recommend for my 2001 XKR. Many thanks.
Old Nov 25, 2022 | 10:24 AM
michaelh's Avatar
You can use anything that meets the spec WSS M97B44-D, assuming your car has the correct stuff already in there.
Jaguar JLM20972 obviously does, as does Ford Premium Super-Plus (although it isn't orange..)
The Jag product used to be more expensive, but not so much now. Heritage shows it at £13.66 (Inc UK VAT) for a 2 litre container
https://parts.jaguarlandroverclassic...ntifreeze.html
which is cheaper than I have found the Ford listed, although ymmv.
Last edited by michaelh; Nov 25, 2022 at 11:07 AM. Reason: put the words in the correct order...
Old Nov 25, 2022 | 10:41 AM
drmike's Avatar
And there is the issue, how on earth can you tell what's already in there? Colour doesn't mean a thing any more. I have a gallon the coolant to spec but I'm not what's there already.
As I understand it there is the risk of a wrong mix creating sludge that can block waterways so a full flush is required. Can I just add some of the new stuff to some of the coolant already in there and see what happens or doesn't it work like that?
Old Nov 25, 2022 | 11:00 AM
Originally Posted by drmike
And there is the issue, how on earth can you tell what's already in there? .....
The same applies to all the fluids.
That's the reason I do a complete fluid change on any 'new' to me vehicle. It picks up on anything that may have been missed in maintenance, gives a baseline for future servicing and removes any doubt.
Old Nov 25, 2022 | 11:04 AM
michaelh's Avatar
Indeed. There's no guarantee, but - from MY 2000 on all cars were fitted with the WSS-spec coolant so it's a safer bet than for earlier cars, and it's what the dealership would have used when it was doing the servicing.
I guess the fail-safe has to be that, if you're not certain what's already in there, then do a full chemical flush.
There's a TSB regarding this linked in motorcarman's post:
https://www.jaguarforums.com/forum/x...3/#post2538528
and one (attached) that contains instructions in the event of a flush being needed.
File Type: pdf
Old Nov 25, 2022 | 11:12 AM
motorcarman's Avatar
TSB for you.
File Type: pdf
Old Nov 25, 2022 | 11:20 AM
drmike's Avatar
Thanks guys. It looks like the mixing would not cause sludge but impair the corrosion protection which I suppose in turn would lead to blockages.
That chemical flush procedure looks very daunting indeed. Very daunting.
Old Nov 25, 2022 | 11:29 AM
michaelh's Avatar
Doc, it's not that bad:- just a tad time consuming. I made the change from DOW years ago and if I can do it without poisoning anybody or setting fire to something, anyone can
Old Nov 25, 2022 | 11:57 AM
drmike's Avatar
Well I guess so. Some planning will be needed.
A 'tad' time consuming. At least I am time rich.
LausDeMaus
Sep 2, 2022 05:52 AM
aeginc77
Mar 10, 2021 04:06 PM
romroc
Oct 31, 2020 04:05 AM
corsa59
Australia - Queensland
Dec 4, 2016 06:56 PM
plums
Jul 8, 2011 01:33 AM
