What do y'all think about a 6-speed?
Old Aug 28, 2007 | 10:47 AM
2000blackxkr's Avatar
Default What do y'all think about a 6-speed?
Ok, i was thinking about it, what would be required to put a 6-speed stick into my xkr.
1. Complete computer re-programing.
2. Custom Peddle assay and cut hole threw fire wall for mounting clutch cable/hydro That begs to be answered, hydro or cable setup?
3. Bell housing. These engines are simply ford of Europe v8's. I would think there has got to be some way to make a 6 bolt up. if not a adapter would be required.
4. probably custom shifter assay for the small area of the current j-pattern shifter.
Which clutch? will the current cross member work? which trans to use? Richmond? Tremec?
any ideas?
Old Aug 28, 2007 | 11:57 AM
ken@britishparts.com's Avatar
Default RE: what do y'all think about a 6-speed?
Did these cars come with manuals in Europe? Maybe you could buy a complete set up from a breaker over there...
Old Aug 28, 2007 | 05:14 PM
I dont think they did. i think they are all auto's
Old Aug 28, 2007 | 07:21 PM
93xj6's Avatar
Doesn't ur car already have a 6 speed auto w/ manual overdrive.
You still want more outta it, cuz idk how much more performance you will get outta a manual. Although, I'm sure you know alot more about it then me, i have yet to learn manual
Old Aug 29, 2007 | 10:39 AM
No, its a 5-speed auto.
So yea, a 6-speed manual would make a difference.
Old Aug 29, 2007 | 11:10 AM
93xj6's Avatar
O ok, right that was after 03 they put in the 6 speed mercedes trannys?
I thought the 00 xkr would have a 6 speed cuz my 00 xk8 has a five, so I thought they would upgrade there.
Old Aug 29, 2007 | 08:45 PM
I wish.. its still the 5-speed auto.
i wish it was a stick.........hummmmm... still thinking about it.....
FUN SWAP...... OR A NIGHTMEAR!!!
Old Sep 19, 2007 | 04:47 PM
Yurikaze's Avatar
I too am interested in a manual swap. I'm really getting sick of attempting to shift my J-gate like my manual cars.
I know the XK8 and BMW 540 use the same automatictransmission, so a 6-speed manual 540 might be a starting point for your research.
Old Sep 19, 2007 | 08:21 PM
Well the good news is that the manual does not have a removable bell housing, SO if they both have the same bell housing then we are doing good. BUT if they don't. and the Jag auto and the BMW auto have a different bell housing. then there is 1 issue.
Can any one shed some light on this?
Old Jun 28, 2008 | 09:12 AM
JgaXkr's Avatar
I have looked into converting my 2000 XKR to a manual transmission as well. I know that Elite & Performance Jaguar in England has converted an XK8 to a manual, however they still have not resolved the electrical issues with communication from the transmission & engine control modules. This is the largest obstacle to overcome, & may proove to be unresolvable. Another option which works quite well is to install a "Speedshift" from Paramount Performance. I can honestally it is the way to go, having installed the kit myself on my own XKR. It involves installing a small ECU-link harness to interupt the J-gate, a shift indicater light & the switch assy which mounts to the back of the steering wheel. This setup is as close to an F1 style shift you will find. I find it more fun to use than the paddles on the new XKR & much more responsive to driver input. I have owned an XJS with a factory 5-speed & find this to be much more fun to drive, it gives you an automatic transmission as well as the option of shifting yourself. You can up & downshift faster than you could with a manual transmission. The best part is the cost is no where near what a manual would potentially cost, is proven to work, & can be installed in app 4 hours, by anyone with basic mechanical ability. If anyone would like more info please let me know. This is just one of the many upgrades I have done to my highly modified XKR.
Old Mar 30, 2019 | 10:57 AM
phatcat67's Avatar
ok, this three is old, but to revive a little, here is another idea to think about:
AM vantage v8 has a 6 speed. same bell, dual mass flywheel and clutch components, they will have a matching pedal hanger, clutch slave etc. only problem to address then is the ECM!
Old Apr 28, 2019 | 10:52 PM
giandanielxk8's Avatar
I bet the V8 vantage transmission costs a pretty penny.
Old Apr 29, 2019 | 09:39 AM
funracer's Avatar
I bet. Depends how bad you want it.
Old May 2, 2019 | 03:53 PM
JagV8's Avatar
Interesting use of the word "only"...
Old May 2, 2019 | 09:54 PM
bcprice36's Avatar
I could be wrong but probably not! That AM with the 6 stick has the Jaguar Engine but the 6 Stick shifts a rear Transaxle and has a long Tube that runs from the Engine to the Transaxle.....By the time you bought all the parts to do this little job….you could probably save enough money to buy the AM as is.....Oh! they are nice Cars...I drove one yesterday!
Billy Clyde in Houston
Cambo
107
Aug 15, 2023 07:30 PM
KevinGS
Aug 26, 2015 03:03 AM
paul-hb
Aug 13, 2015 06:33 PM
Balboa
Aug 6, 2015 10:35 AM
desertdan
Jul 23, 2015 06:40 AM
