Where to buy upper shock mounts
Old May 23, 2014 | 06:21 PM
Jandreu's Avatar
Default Where to buy upper shock mounts
2003 XK8 Vert, need upper shock mounts and upper control arm bushings.
Have looked at Gaudin and SNG Barrett, very expensive.
Any other places to order?
Old May 23, 2014 | 06:42 PM
here is a listing from e-bay (seller is Coventry West) for $135 ea (shows 7 left in stock)
Front Upper Shock Mount Kit Fits 1997 2006 XK8 XKR P N MJA2170BD | eBay
Old May 23, 2014 | 07:25 PM
cjd777's Avatar
Default shock mounts
Just did this and you must remove the paint on the studs. I had one break while using a speed wrench. Go ahead and order shocks, the bushing will be shoot if they haven't been replaced. Removing the ball joint makes for a much easier job when you are putting the top A arm bushings and spacers back together.
Wayne
Old May 23, 2014 | 07:36 PM
Jandreu's Avatar
Wayne
Are you referring to the upper control arm ball joint? I thought this was a press fit that is tough to get out. Would like to go ahead and replace the upper ball joint as it's not expensive if it's something I can do with out a press. I do plan to remove the upper control arm to do the upper shock mount.
Plan to replace the upper control arm bushings also.
Thought about replacing the lower shock bushing but that bad boy is way expensive. Do new shocks come with the bushing?
Old May 23, 2014 | 07:41 PM
Davebc's Avatar
Default SNG Barrett
Ordered two the other day, forum members receive 10% discount. Got the non O/E for $121.50 each plus shipping to Canada. My local dealer wanted $280 each-that's expensive!
Have ordered items from Coventry West before too, great company to deal with.
Old May 23, 2014 | 07:43 PM
cjd777's Avatar
No, just take it off the upright with a splitter if you have to, but a air hammer on the stud pops it right out, just keep the nut on covering the threads.
Wayne
Here is a write up I did on mine and Yes the new shocks have new bushings installed.
https://www.jaguarforums.com/forum/x...rt-2-a-117080/
Old May 23, 2014 | 08:05 PM
Jandreu's Avatar
Cdj777, thanks again. That is what I had planned. Just looked and my lower ball joint on the passenger side has a split boot, may have to replace it.
Car drives great, no shimmy, no noise, no pull however on a rough road or hit a bump and the whole steering column shacks violently. Shocks seam OK, very tight and no bounce. Just got the car with 86K on it. Per service records the sway bar bushings were replaced 3K ago.
Figured I'd start with the upper shock mounts and upper control arm bushings as it has to come off anyway and see how it handles from there. Shocks aren't that expensive so may go ahead and replace them at the same time.
Old May 24, 2014 | 03:16 PM
wolfpck1's Avatar
motorcars ltd carrys the rebuild kits and also the stock upper mount . they also sell a retrofit kit for switching to stock shocks everything completly assembled{may have to call for that} . the kit for 4 wheels was like 1800 am wondering if you call them can maybe get the front only for like 900. seeing that shocks are 120 ish the mounts 200 apiece the boots about 12 thats 332 a shock to rebuild your getting a new spring and no laber to take apart and reinstall the mount. just a thought.
Old May 27, 2014 | 11:35 AM
SNG Barratt USA's Avatar
Former Sponsor
We now stock these priced at $121.50 with your JF discount.
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
1964Daimler
Sep 9, 2015 11:28 AM
EZDriver
Sep 8, 2015 09:25 AM
Tar
Sep 6, 2015 11:24 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
