XK8 Air Conditioning/climate Contol ECU
Old Oct 13, 2018 | 07:14 AM
David.Lipowski's Avatar
Default XK8 Air Conditioning/climate Contol ECU
Hi all,
I am having an issue with my Climate Control. The control/ display unit will only light up a few random if push on and auto and has no display. The lights then go off when any button is pressed!
Swapping for a known good unit had no change so the Climate Control ECU was suggested. I don't know where this is located however, can anyone point me in the right direction? I have searched on the forums but not been able to find anything.
Many thanks,
David
Old Oct 13, 2018 | 07:46 AM
avern1's Avatar
The first thing we will need to know to be helpful is "what are you working on" model and year in your signature would make it easier to get assistance and you would not have to remember to type it in on each post. You can go to the USER CP at the top of the page and add the info to your signature.
So let us know what year XK8 and we can get started with help.
Old Oct 13, 2018 | 07:59 AM
Ah yes sorry. I though I had a signature set up. I will log into PC and sort.
It's a 1998 XKR Coupe.
Thanks,
David
Old Oct 13, 2018 | 08:06 AM
Checking Sig!
Old Oct 16, 2018 | 03:29 PM
So my signature works on the laptop but not mobile! Anyone have any ideas where I can find the climate control ecu on 1998 XKR? Found the body control module at passager side behind glove box.
David
1998 XKR
Old Oct 17, 2018 | 08:43 AM
dibbit's Avatar
David
1998 XKR
According to the Electrical Guide for my 2001, its next to (left) the body control module on a LHD car (behind the steering wheel on a right hand drive car) - of course we don't know if you have a LHD or RHD vehicle. Have a look in the Electrical Guide for your model car if you can't find it.
Old Oct 17, 2018 | 08:51 AM
Johnken's Avatar
BCM is behind the passenger air bag. I don't think you need to remove glove box but someone please check me on that.
John
Old Oct 17, 2018 | 09:15 AM
Thanks guys, it's a RHD car. I've found the BCM which I reckon can get out with glove box in place, just not been able to locate the climate control ECU, will see if can find the electrical guide. Cheers.
Old Oct 18, 2018 | 02:56 AM
dibbit's Avatar
On a RHD car the climate control ECU is not next to the BCM - its on the drivers side - its shown as to the left and behind the instrument pack. You definitely need to check this with a diagram for your model year car.
Old Oct 18, 2018 | 02:57 PM
Was able to access from panel under steering wheel. Some contortions removed the screws and squeezed it out!
FLYINGFOX4475
May 11, 2017 11:56 AM
NW1996
Dec 19, 2013 07:48 AM
wallacestone
Jan 20, 2013 07:51 AM
gabrielduenas
Jul 27, 2012 07:50 PM
iownme
Jul 4, 2011 03:39 PM
