Xk8 front shock mount nut (the three on each side)
Old Feb 5, 2025 | 09:33 AM
AbnMike's Avatar
Default Xk8 front shock mount nut (the three on each side)
does anyone know the part number or equivalent for the shock mount nuts - not the center nut, but the three that connect the tower to the body.
Thanks.
Old Feb 5, 2025 | 09:52 AM
AbnMike's Avatar
I think I found it - jfx10805b
Old Feb 5, 2025 | 09:53 AM
motorcarman's Avatar
Do you mean the absolutely common M8 x 1.25mm nuts?
Old Feb 5, 2025 | 09:56 AM
AbnMike's Avatar
If that's the correct one then sure. The Jag parts catalogue says it is part number jfx10805b flange nut.
https://www.terrysjag.com/product/JFX10805B.html
Old Feb 5, 2025 | 10:04 AM
Jon89's Avatar
You should be able to find them at the local hardware store. Just take one with you when you go and match 'em up....
Old Feb 5, 2025 | 11:30 AM
baxtor's Avatar
Thanks.
Just be aware, M8 is OEM and URO mounts but it could be 5/16" UNC if the mount happens to be Welsh.
Old Feb 6, 2025 | 05:38 AM
cjd777's Avatar
Like baxtor said, the maker of the mount makes a difference.
The one problem several have had over the years is the amount of paint or powder coat on the threads.
If new, always do a threading of a nut on each stud before install, will save you breaking one off, and then it becomes a nightmare.
Old Feb 6, 2025 | 06:50 AM
AbnMike's Avatar
These came with the car so not sure how to tell if it's URO or OEM unless I take it to the store and try each bolt? Are they close enough where each would fit? How would I tell if it's the exact correct fit if they both will -kinda- fit?
I'm not a bolt and nut expert.
Old Feb 6, 2025 | 07:53 AM
dibbit's Avatar
Do you not have a bucket full of odd nuts, bolts, screws, nails, random metal brackets, bits of pipe, Ikea fixings and rust in your shed?
Old Feb 6, 2025 | 07:56 AM
wymjym's Avatar
No they will not 'sort of' fit. Do not do that!
If you have one original. take it to a hardware store and ask for assistance is matching the thread.
WJ
cs81srq
Feb 13, 2023 01:11 PM
TropicCat
May 11, 2021 11:04 AM
Chuck Schexnayder
Dec 22, 2017 05:58 PM
razorboy
May 15, 2017 02:19 PM
MikeofBonsall
Sep 14, 2016 07:12 AM
