XK8 Head gaskets
Old Feb 7, 2010 | 05:29 PM
stephen garrett's Avatar
Default XK8 Head gaskets
Hi
Need two head gaskets replaced. I have being quoted £1500 aprox $1200. Does this sound O.K. Please give me quick reply. As I need to know as soon as.My car is a 2000 XK8 4.00 L
Steve
Old Feb 7, 2010 | 05:55 PM
Gus's Avatar
Gus
Steve,
Do the headlights, bumper and hood come with it? That seems a little high.
Old Feb 7, 2010 | 06:14 PM
Hi Gus,
Got the original convertion wrong. more like $1800. I have been assured that everything that neads to be done. Will be done. The engine only has 45,000 miles on it. A bit early for head gaskets in my opinion. But have bubbles coming through the cooling system. Any idea's ? or advice.
Thanks for quick responce
Steve
Old Feb 7, 2010 | 06:57 PM
Gus's Avatar
Gus
Steve
I misread your post I thought it said headlight not head gasket. I would imagine this would be expensive did he say why with such low mileage?
Old Feb 7, 2010 | 07:54 PM
test point's Avatar
Have you had overheating problems? Replaced water pump and or thermostat? If not, is that included in the head gasket repair? Reading posts from professionals there is little simple about replacing head gaskets because of the potential for other damage.
Old Feb 7, 2010 | 11:01 PM
vwsamba's Avatar
that's more like $2200 with the current exchange rate but its just 1500 units of currency where you live so its the same as $1500 for someone living in the US. either way it sounds cheap to me for all that work.
Old Feb 8, 2010 | 08:01 AM
Hi Guy's
Thanks for input. At first I thought it was A over heating problem. The upper radiator hose blew. After replacing, I found other leeks in cooling system. I was advised to Start engine from cold with cooant system full and open. Was told to watch for bubbles rising when engine gets to running tempreture. Apparently The bubbles indicate Exaust gasses escaping into cooling system. Looks like I will have to bite the bullet.
Thanks again
Steve
Old Feb 8, 2010 | 09:38 AM
oldmots's Avatar
If you are getting bubbles in the coolant with the engine running, get the gaskets changed quick, and I would not drive the car anymore. If exhaust can get into the coolant, coolant can get back into the cylinders and the oil. Don't wait, enough coolant in the oil can wipe out your bearings and you could lose the engine. The price you got quoted is a good one, go...go..go.
Old Feb 8, 2010 | 04:39 PM
Thank's guys
Booked in for tomorrow. (lets hope there is nothing else).
thanks again
steve
aholbro1
Dec 29, 2024 06:46 PM
Razor
Aug 28, 2019 08:34 PM
vicom
Sep 17, 2015 03:32 AM
bavareze
Sep 11, 2015 01:49 AM
1964Daimler
Sep 9, 2015 11:20 AM
