XKR access to fuel pumps
Old Oct 15, 2011 | 05:19 PM
bgoldstucker's Avatar
Default XKR access to fuel pumps
Dear All,
I am the proud owner of a 2000 XKR perfromance version (R).
The fuel pumps went bad and the instructions (for an XK8)posted on various internet pages do not match my car. The first difference is that the tank has the sender unit on the side of the trunk and not attached to the pump like the XK8. Second difference is that my car has two pumps (the tank has a waring label that points out that this version has two pumps) The third difference and this is the big one; the lines that go into the tank are not accesible behind the differential. They are covered by a head-shield and it appears as if the only way to remove the heat shield is to drop the rear differential!!!! I spent 3 hours today with the car on a lift and two mechanics and we could not figure out how to disconnect the fuel lines (in and return). Any advise would be very much appreciated
Thank you to all.
Regards,
B.Goldstucker
Old Oct 15, 2011 | 05:37 PM
Gus's Avatar
Gus
The tank and pump replacement are similar only that the XKR has 2 pumps. The attached link has information that should help especially with disconnecting the fuel lines.
Jaguar fuel pump replacement xk8
Old Oct 15, 2011 | 05:48 PM
Paul Pavlik's Avatar
In addition to Gus's Excellent Info, see Post #52 of this thread:
https://www.jaguarforums.com/forum/xk8-xkr-17/aaaaaaaah-%25%24-%40^%25-opportunists-61394/page3/
avos describes a Special Tool that he fabricated that allows access to the Fuel Fittings under the Car.
Old Oct 15, 2011 | 10:42 PM
maxwdg's Avatar
Please, Please make that tool! I so wish that I had done so two weeks ago. Good luck to you!
Old Oct 16, 2011 | 05:50 PM
Dear All,
Thank you for your answers.
Nevertheless, my car has a heat shield right on top of the differential that hides the fuel lines. The fuel lines run around the back left shock towards the center of the car and then run underneath the aluminum heat shield. The heat shield is approximately ten by eight inches. My mechanic and I lifted the car and compared several printouts of the Internet with the layout of my car and they do not match. A third mechanic that had worked on an Xkr before confirmed that you have to drop the differential to remove the heat shield and detach the fuel lines.
Old Oct 16, 2011 | 06:36 PM
Gus's Avatar
Gus
Sorry we were unable to help!
Old Oct 16, 2011 | 06:53 PM
plums's Avatar
And did you read the pdf that Gus pointed at?
The issue here is getting at the two fuel lines entering the bottom rear of the tank from the bottom of the car. I kept looking where the fuel lines from the fuel filter went under the heat shield thinking that is the location where the lines entered the tank.
If you really want to drop the differential go right ahead. Otherwise take the time to actually read what has been posted.
Old Oct 17, 2011 | 12:24 AM
avos's Avatar
My 2000 XKR doesn't have a heat shield where you mention it, and JTIS doesn't mention any heat shield or the need to lower the diff, so it sounds a bit non-standard to me.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
Charlene n John
Sep 28, 2015 06:01 AM
deanh
Sep 6, 2015 08:20 PM
Sprayall
Sep 3, 2015 07:49 PM
