XKR Air Intake Silencer-delete Writeup c/w pics!
Old Dec 16, 2016 | 08:32 AM
Burl's Avatar
You are correct. This is for the 2006 XKR that I was planning the intake tube mod. I don't think the air passing thru the supercharger is going to have the resonant pulses of the normally aspirated engine. The supercharger will have a fairly stead pull on the low pressure side. I still wonder if the smooth aluminum aftermarket tube with rubber elbows will give more total air flow. The air temperature running higher as measured with the aluminum tube may be indicating more air coming thru to the engine at a given velocity.
Old Dec 16, 2016 | 02:22 PM
fmertz's Avatar
Originally Posted by SeismicGuy
All of those nubs and pockets were there to reduce the intake noise rather than improve performance.
Apparently, the design is to reduce noise _for_ improved performance.
air-intake-resonator
Kevin Burnaby
Jun 28, 2020 08:04 AM
cissdm
May 3, 2016 06:02 AM
tberg
Sep 7, 2015 07:32 AM
philwarner
Sep 5, 2015 10:05 AM
TC Johnson
Sep 2, 2015 09:30 AM
