XKRs no sound from headunit.
Old Apr 14, 2018 | 05:28 AM
dav3uk's Avatar
Question XKRs no sound from headunit.
Hi all I am in the UK and I have a very late registered XKRs with the Alpine sound system. Suddenly there is no sound, the head unit works just fine but no sound from speakers. It doesn't matter the source. I have checked all the fuses listed both on US and UK guides and the ones in the handbook for the car and all are ok. I have had the centre console out and checked the back of the head unit and both the yellow and white connectors are in place. It all points to the power amp in the boot/trunk is there any way to test that it is powering up. Scratching my head here at the moment.
Old Apr 14, 2018 | 06:14 PM
michaelh's Avatar
Did you catch F18 (30A) in the trunk fusebox?
Old Apr 14, 2018 | 06:30 PM
Lady Penelope's Avatar
Put your hand on the amplifier after 5 minutes and feel if it gets warm , not all models have a separate amplifier . You should hear a cooling fan also in the amplifier .
Old Apr 15, 2018 | 03:33 AM
dav3uk's Avatar
Yes checked fuse 18, even replaced it just in case, I will check for heat and fan. is the amp live when head unit on or when ignition on, if only when head unit has it got a signal input to trigger it, does it use the same signal as the antenna? is there a link between the two?
Old Apr 15, 2018 | 04:21 AM
frankc's Avatar
This has got me wondering if its something to do with the mute button? Or even the phone, if you have one.
I would try pushing the buttons that separate the different functions, bottom left of head unit. Its often the simplest explanations that are the best. (I did read the "no matter the source" bit)
Another thing to try in case it is something to do with the above is a battery reset, you will need your radio code though. If it is functions gone wrong that should reset them.
Old Apr 15, 2018 | 11:03 AM
dav3uk's Avatar
I have already tried the power off and leave for 10 mins. but nothing. The amp does not heat up and there is no noise if there is a fan in it. has anyone got the colour codes for the cables so I can try to put power direct to it as it seems there is either no power getting to it or its gone pop.
Old Apr 15, 2018 | 11:38 AM
http://www.jagrepair.com/images/Auto...79toB09096.pdf
Notice the VIN # applicability on page 3 and the print you want is on page 76 and the 3 different stereo system options on the following pages .
Notice the F31 fuse on the Brown / Red wire
Old Apr 15, 2018 | 11:53 AM
dav3uk's Avatar
Thank you thats an amazing document however is that for the x100 model XK this seems to be for the later model as there is a lot of stuff on it that I haven't got....lol would you have access to a 2005 model version?
Old Apr 15, 2018 | 01:29 PM
2004 and 2005 are missing maybe 2003 will match
http://www.jagrepair.com/images/Auto.../jagxk2003.pdf
Old Apr 15, 2018 | 03:11 PM
michaelh's Avatar
The 2003 JTIS wiring diagram linked to by Lady P in post #9 is the most recent, AFAIK.
I imagine that you have the NAV system so communication between the head unit/CD player is routed through the NAV module.
Might be as simple as loose connectors at the amp?
Power to the amp is always present irrespective of the ignition switch state, on IC16-3 and IC16-9 (brown/green wires):
Last edited by michaelh; Apr 15, 2018 at 05:17 PM. Reason: correct pinouts on IC16
Old Apr 23, 2018 | 08:01 AM
dav3uk's Avatar
So I am at a loss now. All connectors are sound all fuses are replaced, there is power at the amp but still no sound, I am starting to think its the amp has gone....
I have removed it and as per a lot of Jaguars there is evidence of water seeping in around the boot/trunk opening seam weld lines. There is some rust on the case of the amp so looks like its been dripped on over the years.
Trying to find a replacement amp to try now.......may take a while
Old Apr 24, 2018 | 05:50 AM
frankc's Avatar
Have you tried making a phone call through the system? Or a tape or disc?
If it were the amp you would hear nothing from them either.
Old Apr 24, 2018 | 11:57 AM
dav3uk's Avatar
Yes nothing from any source. All sources seem to work/have power. you can change discs in the changer, the phone is still connected via bluetooth but no sound but I can search and make a call from the head unit. I am now using contact cleaner on everything to see if I can get anything back.
Old Jul 4, 2018 | 08:28 AM
dav3uk's Avatar
So after much head scratching and testing I can confirm that it was the power amplifier located in the CD NAV stack that had gone. Eventually found a replacement second hand and its all working fine now. Thanks for everyones input. now to try to get my airbag light turned off....
Old Jul 4, 2018 | 10:06 AM
toaster's Avatar
The power aerial goes up and down?
Old Jul 14, 2018 | 02:18 AM
dav3uk's Avatar
Yes there was power to everything, it was the amplifier had gone faulty. Replaced and all working again.
jagosaurus
Apr 13, 2020 03:00 PM
Bergy
Nov 8, 2015 01:55 PM
mattsiss
Feb 28, 2013 09:34 AM
androulakis
Oct 4, 2007 09:13 AM
