Compact Disk Changer in Boot
Old 05-11-2015, 12:48 PM
WayneCountyBill's Avatar
Default Compact Disk Changer in Boot
Hi, everyone. I have a question regarding the Compact Disk Changer that was recently installed in the boot of my X-Type. It is hooked up, my radio works, my single CD player works, but when I press the button to release the cartridge the cartridge does not open/come out of the housing unit. I have tried it with the engine running, I have tried it with the key to accessory mode. I've tried it with the key in the accessory mode and pressing the CDC button. I even looked to see if there is a separate fuse for the CDC, but I can't find one. Any assistance would be appreciated. Thanks.
Old 05-11-2015, 01:03 PM
astromorg's Avatar
The cassette can be released manually by inserting a thin steel strip, about 25 thou thick - I use a 6 inch steel rule - underneath the cassette, in the centre. Slide the strip towards the rear of the car and the release catch will be triggered.
The following 2 users liked this post by astromorg:
bigdiver (05-12-2015), WayneCountyBill (05-12-2015)
Old 05-12-2015, 04:40 AM
Default Thanks!
Thank you. I will try that later today. I need to find a steel ruler. Bill
Old 05-12-2015, 06:22 PM
Default Hi "Astromorg"
I got a steel ruler and tried what you suggested. No luck at all. I'm going to have a buddy of mine double check. I had the accessory "on" while I did this to get power to the Changer. By any chance, do you have any other suggestions? Thanks! WayneCountyBill in Ohio USA.
Old 05-12-2015, 06:33 PM
sov211's Avatar
Received 2,134 Likes on 1,308 Posts
You do know that your dealer has to reflash the system so that it recognises that the CD unit is installed? otherwise it simply will not work - you will be pushing the CDC button in vain. I have retrofitted 3 of these CD changers myself (that was easy) then taken them to my dealer for the reflash.
WayneCountyBill (05-13-2015)
Old 05-13-2015, 07:04 AM
Default Thanks, Sov211
Ok. Well, that doesn't sound good. Thanks! Have a good day.
Old 05-13-2015, 09:05 PM
Received 7,879 Likes on 4,763 Posts
There are 2 connections to the CDDJ. (Compact disc-disc jockey)
One is the electrical connector and the other is the D2B network or BOF (black optical fibre).
The electrical connection sends a 'signal' to the CDDJ and the BOF is LOOPED back to the head unit. You can unplug the BOF at the CDDJ and see if one of the fibres flashes a red light from the head unit when the unit is power up. (key on radio on)
The head unit probably does not recognize the CDDJ as sov211 has stated.
Here is some info I gathered from this forum as well as when I worked at the dealer and attended NP02 (New Product 2002 aka X400)
I believe all this is in the large file area that I (and others) have uploaded.
You can install other devices on the D2B network (ie. PHONE) but they MUST be in a specific order AND configured to the head unit.
bob gauff
File Type: pdf
File Type: pdf
WayneCountyBill (05-14-2015)
Old 05-14-2015, 07:09 AM
Default Thanks, Bob (...and everyone)
I printed your attachments and will share with my technician. He is very knowledgeable, so I'm not sure where the disconnect (get it??) is with this installation. Thanks, again. Bill
Old 05-18-2015, 07:00 AM
flyrr100's Avatar
I had a cassette player and a six CD in the trunk. I took the trunk CD out and replaced the cassette with an eBay sorced in-dash CD player. I sold the CD on eBay for around $50.
I have an ACM so I installed a Sirrius in the ash tray. Now my CDC button is my iPod/Sirrius selector.
I can honestly say I havent listened to a CD in over a year. Sirrius is the way to go.
I can also run my iPhone through the ACM. So I can use Pandora, or use the GPS app.
Finbarr1975
09-16-2023 02:52 PM
vwbusbits
10-13-2015 03:43 AM
GoNavyMike
09-28-2015 08:56 AM
Woznaldo
09-26-2015 11:02 AM
Quick Reply: Compact Disk Changer in Boot
