XKR 2001 very big oil leak in front of the engine (Resolved)
hiii Yesterday driving back home in normal city traffic around 60 km/h suddenly got smoke all around and behind the car . I stopped the car . The engine was still running normally and not heating . Opened the bonnet . Oil was everywhere dripping . I started the engine and it was a real oil fountain coming out .I checked the dipstick ; no oil anymore . So all the oil was gone in one or two minutes . Before i didn't have any even small oil leakage I brought the car home Checked a little but can't find any oil hose that is broken . I suppose it must be a big leak somewhere as i lost all the oil so fast . Not easy to see in the front of the engine before dismantling .
Does anybody have a idea what could have broken . Any body else has had the same problem ?
Jaguar makes a revised hose that a lot stronger than the original
Removal of the lower cover is usually held on by screws or plastic rivets.
The process is not too hard to me, just put your car up or jack stands and get er done, don't forget to add oil lol
Replace all hoses that are leaking, unless you find something else
2000 Jaguar XKR Parts - Direct JPLV Porsche Parts.com
https://www.jaguarforums.com/forum/x...er-hose-50378/
forum
forum
Or remove your old lines,take to a hydraulic hose company or ship it off, let them make a much more improved design over jaguar for a cheaper price !!!
Be sure to insect the hoses that the return and feed line go to as well
Mine showed minor stress cracks, I put 5/8'' hose clamps on the ends with a piece of silicone hose, so if they rupture before I get to them, it will only leak and not ruin my engine until I'm ready to replace them soon.
That diagram is of the power steering oil cooler.
The engine oil cooler is the small frontmost rectangular radiator and has 4 possible hoses to split.
As stated, they are prone to rupture at the connector and there are improved hoses now available. See https://www.jaguarforums.com/forum/x...er-hose-50378/
marcvb (11-27-2014)
That's great news!
When spring is here, all 4 of mine are coming off next.
A local company by me uses silicone hosing for commercial trucks and says the lines they make, out last the vehicles. I'm down for that.
They even said they can mock me up some silicone valley hoses that will never good bad as well. 1 million mile warranty.
what diagram are you talking about? This just happened to me yesterday. Wondering if you knew where I could find or were willing to provide a list of all components needed to fix the problem, and possibly a summary of what steps need to be takin to complete said task
Received 1,579 Likes
when removing the engine side oil cooler hoses it helps to have a small telescoping mirror to see and manipulate the attachment bolt. Other than that the job is straightforward.
it bears repeating that these hoses will fail. Don’t rely on just an o-ring replacement.
Even if only one hose is leaking, replace them all.
Z
The following 2 users liked this post by zray:
Bobbys02XK8 (06-27-2023),
michaelh (06-26-2023)
BrentGardner
26
04-17-2024 05:19 PM
X_Type_South_Africa
12-09-2015 05:37 PM
