Engine Bay - Cleaning
Old Dec 15, 2012 | 04:51 PM
magmedia's Avatar
Default Engine Bay - Cleaning
Hello-
Nice weather today in the east, so I did a quick under-hood cleanup. I used some window cleaner, a toothbrush and microfiber cloth. Followed up with a little armor all.
Pics from cellphone, forgive the (lack of) quality!
Thanks-
-mag
Attached Thumbnails Engine Bay - Cleaning-img_0659-small-.jpg   Engine Bay - Cleaning-img_0660-small-.jpg   Engine Bay - Cleaning-img_0661-small-.jpg   Engine Bay - Cleaning-img_0662-small-.jpg   Engine Bay - Cleaning-img_0663-small-.jpg
Old Dec 15, 2012 | 09:53 PM
XJL's Avatar
XJL
Very Nice! Looks better than showroom.
Old Dec 19, 2012 | 10:10 AM
peddlarbob's Avatar
Default #31 1992 Canadian limited edition last 100 V12
Last edited by peddlarbob; Dec 21, 2012 at 01:43 PM. Reason: Story left did not post with picture. Picture shows the results of three months work detailing this engine.
Old Dec 21, 2012 | 01:01 PM
WayneCountyBill's Avatar
Default Looks Great!
Nice bay! Thanks for posting - sharing. I wipe down my engine bay then go over it with the armor all as well.
Attached Thumbnails Engine Bay - Cleaning-gedc1362.jpg   Engine Bay - Cleaning-gedc1364.jpg
Old Dec 21, 2012 | 02:36 PM
joycesjag's Avatar
Mighty fine looking engine compartments gentlemen, thanks for sharing the pics.
Old Jun 29, 2013 | 11:08 AM
PigletJohn's Avatar
what is the window cleaner for?
Old Apr 2, 2019 | 02:48 PM
Lewis_'s Avatar
Both engines look beautiful. What is the “armour” stuff your both using?
Thank you
Old Apr 3, 2019 | 05:49 PM
PigletJohn's Avatar
The product is called "Armorall"
it is a sort of polish that is absorbed into the surface of dull and faded plastics and some paint and restores the colour and shine. Usually sold in trigger-spray bottles but you can also get a 5 litre/1 gallon container to refill them. Can also be applied with brush or rag.
It leaves the surface slippery so is not suitable for pedals, grips, motorcycycle tyres etc
refill
I use it.
clean supercharger
Old Apr 3, 2019 | 06:15 PM
Lewis_'s Avatar
Thank you for that John, I will order some. On the two X type pics what would you recommend to use on the cylinder heads to bring them up as clean as they appear?
Many thanks
Old Apr 3, 2019 | 06:32 PM
PigletJohn's Avatar
Many thanks
Don't know. My engine is intended to be hidden under the plastic covers, and the castings are not smooth. A brass-bristled wire brush in a drill or dremel will clean them up, and a metal polish such as Solvol Autosol with a brush, rag or electric toothbrush will improve them and get the dirt and corrosion off most aluminium, but some castings won't come bright and shiny.
I expect you have valeting and car show mags or suppliers that will have comparable products in your market. I also replace dull or corroded screws, washers and fastenings, if accessible and safe, with stainless. You need Nickel Grease to prevent it seizing.
Old Apr 3, 2019 | 06:36 PM
PigletJohn's Avatar
Update: I see you are in UK. I sometimes get specialist rebuild and cosmetic materials from a company called Frosts.
https://www.frost.co.uk/car-care-clean-detail.html
These companies will do their best to separate you from your money.
Forcedair1
Sep 8, 2025 01:57 PM
cissdm
May 3, 2016 06:02 AM
user 652867429824
Sep 5, 2015 12:53 PM
bdboyle
Sep 4, 2015 06:16 AM
OkieTim
Sep 2, 2015 12:48 PM
