Help with Steering Wheel Removal
Old Feb 1, 2018 | 07:42 AM
Dougrobling's Avatar
Default Help with Steering Wheel Removal
I have searched and found where several members have removed their steering wheel, brut cannot find instructions on how it's done. (Other than disconnect the battery and it requiring a jewels screwdriver)
My cruise control buttons have to be mashed down multiple time to work and the Dealership said the airbag must be removed to replace the switch set....
Thanks for any help with this,
Doug
Old Feb 1, 2018 | 08:17 AM
mshedden's Avatar
Any reason its not covered by warranty?
Old Feb 1, 2018 | 10:07 AM
Default Steering Wheel Help
The car is now out of its warranty period.
Old Feb 1, 2018 | 05:28 PM
Unhingd's Avatar
Looking at the shop manual, removing the steering wheel is not a trivial project. All the switch wiring and the airbag present some serious challenges. I would leave this project to a qualified Jag mechanic.
Old Feb 1, 2018 | 05:38 PM
uncheel's Avatar
I agree this procedure requires some care. You don't want to set off an airbag.
Meanwhile, I'm surprised you are out of warranty - my MY14 just came out last August.
Old Feb 1, 2018 | 06:41 PM
DJS's Avatar
DJS
I was going to say the same thing about the warranty, but it must be the mileage.
Edit: guess I was confused, thought his was later than 2014.
Old Feb 1, 2018 | 09:25 PM
Car only has 20k miles on it, but it’s 48 months has passed........
Old Feb 1, 2018 | 10:03 PM
OzXFR's Avatar
Judging by the instructions in the Workshop Manual it shouldn't be that hard to do, the only real problem may be the two "special tools" that are needed - the drivers's airbag removal tool JLR-501-170 and the clockspring locking tool 211-326. I recall reading somewhere that a small flat blade screwdriver can be used in place of the airbag removal tool as long as you are reasonable dexterous (rules me out!) but I'm not so sure if there is a way around the clockspring locking tool although I suspect a half-decent mechanic/workshop would know a way.
Anyway, here are the two procedures from the Workshop Manual:
File Type: pdf
File Type: pdf
Old May 13, 2020 | 08:21 AM
dpark's Avatar
In case anyone comes across this in the future, I just replaced my steering wheel with a flat bottom and wanted to share my experience.
Don't be scared or intimidated. This is not a difficult job if you know how to turn a wrench. You don't need the "special tools", a straight pick will do the job of getting to the airbag clips behind the steering wheel.
If you search eBay for a 'hook and pick set', these sets can be picked up for AU$10.
Don't forget to disconnect the negative battery terminal before you get started.
You don't need to remove the clock spring if you're just swapping over the steering wheel. Make sure you keep the clock spring as still as possible. Some movement won't hurt, but don't let it go crazy.
Take note of the markings on the steering wheel when you remove it and align the markings when you put the wheel/replacement wheel back on.
Put some blue thread locker on the bolt and tighten to 63nm.
Overall, it's a 3/10 for difficulty. The thing that will stress you out is worrying about your airbag deploying. Once you get over that fear, it's a very easy job.
Old May 13, 2020 | 09:13 AM
scm's Avatar
scm
The advice I've seen is not to disconnect the battery until you've released the airbag clips as you'll need to turn the steering wheel in both directions for access.
Old Aug 9, 2025 | 03:50 PM
graybeardnw's Avatar
Also a 13/16 spark plug socket will also fit the 21mm bolt if you have one. Here are a few reference photos fyi first is the back of the airbag with wires disconnected
Old Aug 19, 2025 | 11:09 AM
Life And Projects By Austin YOUTUBE's Avatar
Iv'e done this in 2 different videos, here you go!
Googsy
May 16, 2015 11:58 AM
bobzjag
Jul 19, 2014 10:04 AM
mikebaker3
Nov 24, 2013 11:17 AM
fippsland
Oct 24, 2009 04:48 AM
super_jag
Nov 21, 2008 01:38 PM
