how to remove trim piece which houses start/stop button
Old Dec 2, 2020 | 08:16 AM
iownme's Avatar
Default how to remove trim piece which houses start/stop button
i want to add a switch to the lower trim piece which houses the engine stop/start button... any tabs to watch out for?
does it come out easily?
(2015 coupe)
Old Dec 2, 2020 | 08:25 AM
Jaguar1611's Avatar
If you take a flexible business card/credit card and fold it in a half circle, the whole start stop assy comes out.
Old Dec 2, 2020 | 08:27 AM
Ray Ray's Avatar
very easy, use a plastic pry tool, insert it under the panel, best to start with the area between the piece and the cupholder, and just pry up.
the piece is very strong so don't worry about breaking it.
Old Dec 2, 2020 | 09:21 AM
iownme's Avatar
sounds easy! ...thanks!
Old Dec 2, 2020 | 09:45 AM
Therock88's Avatar
(2015 coupe)
As suggested, lift up from the back with a plastic pry tool or similar and then pull back. An alternative option that I did before switching to the fixed-wing, is to put a toggle in the existing hole under the dash. Your call though.
If you choose to remove the panel to install...This video is a good overview:
DC
Old Dec 2, 2020 | 10:12 AM
iownme's Avatar
great, thanks, i'll check that first as i have the toggle switch already.
any issues with bumping it accidently?
the video just made it very understandable! thanks
Old Dec 2, 2020 | 10:28 AM
Therock88's Avatar
Nope. It is pretty well recessed. I am sure there are larger drivers than me....But I am 6'4" and 225 LBS, and I do not bump it. (It is now used for my Methanol/Water Injection to totally disable the system when I do not want it running at all and I still never bump it...But you may??).
You could also use a smaller, or different style switch if you are concerned.
DC
Old Dec 2, 2020 | 11:21 AM
iownme's Avatar
i just checked and it looks like a good location to me.
Old Dec 2, 2020 | 01:34 PM
iownme's Avatar
all done. i used the location you suggested.
pretty tight back there to solder the wires but do-able
thanks for the info
OzXFR
Aug 16, 2023 08:47 PM
rickkym
Feb 17, 2020 06:28 PM
XJR033
Oct 16, 2018 05:45 AM
farkle-edina
May 24, 2016 10:46 AM
lexoman
May 9, 2011 08:21 AM
