Cloned dealer scan tool
Old Jul 12, 2012 | 09:46 PM
  #61
plums's Avatar
There are two things you can do to prevent a connection to the topix server.
-- disable wifi and wired connections on your laptop, either in windows, the bios, or both
-- put an entry in your hosts file for the topix server that points at 127.0.0.1
The first option is the better option because you may not know all of the host names that IDS/SDD talks to.
You can also ghost the current state of the machine so that if anything happens you can revert to the previous state.
Old Jul 12, 2012 | 09:52 PM
  #62
plums's Avatar
Originally Posted by Cambo351
Yeah but they screw you over....
1-year £614,25, 1-month £404,25, 1-week £246,75, 1-day £141,25, 1-hour £120,75
Multiply by 1.56 to get USD....
Mitsubishi and Mazda are $19.95/day. Almost everyone else is under $40/day.
Old Jul 13, 2012 | 12:21 AM
  #63
Escolar's Avatar
This might be slightly off topic, but seems like the right crowd to get an answer:
I'm looking for PIDs for the tire pressures on a 2011 XF Premium. I hope to use this with my ELM 327 and Torque Pro to monitor my actual tire pressure at will. Might need scaling factors to convert the signal to PSI, too.
Old Jul 13, 2012 | 01:56 AM
  #64
Cambo's Avatar
Originally Posted by xjrguy
At DVD 125 patch four, [known as DVD 125.04] they took that away from us; the only way into Legacy IDS was through SDD once it determined there was no coverage for the older vehicle. SDD handed off the VIN number and launched an IDS session accordingly. I keep a Toughbook around with DVD 125.03 so I can use on older cars and get into IDS. I can only use it on older cars now because they also took away it's ability to retrieve newer calibration files.
OK now it's starting to become clearer...i think...
With version 125.04 and newer, connect to an X350 and you get SDD because the car is newer, connect to an X308 and you get Legacy IDS because the car is older.
With version 125.03, connect to an X350 and you have the choice between SDD or Legacy IDS, connect to an X308 and, well you just get Legacy IDS...
Yep the pricing via Topix makes anything less than a 1-year subscription a painful waste...
Old Jul 13, 2012 | 02:53 AM
  #65
plums's Avatar
Well it might be painfully expensive, but not necessarily a painful waste depending on the circumstances.
Of course, it is wastefully painful in any case
Old Jul 13, 2012 | 05:13 AM
  #66
Cambo's Avatar
Proper content, grammar, spelling, punctuation and
formatting are essential to conveying information clearly.
Ohne scheiss! Ja du bist der echte grammatik-Polizist.
Old Jul 13, 2012 | 05:49 AM
  #67
ooootis's Avatar
ROFLMAO
Old Jul 13, 2012 | 10:46 AM
  #68
xjrguy's Avatar
Old Jul 13, 2012 | 11:00 AM
  #69
xjrguy's Avatar
Yes, that's pretty much it. However, what I didn't say and probably should have, is that to launch IDS after the introduction of SDD, you have to go to the program folder and locate the launch program and send a shortcut to the desktop for IDS. It's not like they made provision for you to use either one. Once SDD hit you were not supposed to use IDS unless there was no vehicle coverage. They soon figured out there was a way around that, and they plugged that hole.
Sorry for the omission!
Cheers,
Old Jul 13, 2012 | 10:13 PM
  #70
03Xtype's Avatar
I've just discovered that the Mongoose has limitations compared to the VCM.
The Mongoose only works with the software running as SDD, whereas the VCM will let you run the software as Legacy IDS. It's a completey different format, and as it turns out, not all functions are available in the basic SDD.
Actual example right now, I bought a new CD/Radio to replace my Tape/Radio in the XJR. It didn't come with a Radio Code, but i fitted it & it didn't ask for a code, so great. Now I had the battery disconnected for a longer period, and it asks for a code. I don't have the VIN of the donor car, my original code doesn't work. So, into the SDD & try to find where I can reset the code. I've looked everywhere & tried everything, cannot find it.
Now there is a "gold key" button in the SDD, which is something to do with Locked Functions, i've now discovered is also known as Engineering Mode. Apparently in this locked function are all the sneaky wonderful things you might well need, such as how to reset a radio code.
Clicking on the key brings up a request for another password, based on a "seed" that is derived from the VIN of the vehicle you're connected to and the session number.
I have no idea where to get this password from, probably via Topix if you have a subscription, or maybe direct from Jag themselves. I've asked the guy I got the credentials from about it & he didn't know. He never saw this Golden Key before, because he uses a VCM and runs the software as IDS Legacy. Apparently in IDS Legacy there is the function to reset a Radio Code, very easy to find...
So there are a number of functions available to VCM users, that Mongoose owners can't access, without the full subscription it seems.
I'm bummed out, the whole reason I invested in the Mongoose & IDS/SDD was to solve these stupid problems, and it seems I can't....
Mercedes has the same developer mode like what your referring to. Many people have some sort of keygen program to figure out the code to unlock. Maybe some one has a keygen for jag.
Old Jul 18, 2012 | 03:02 AM
  #71
u102768's Avatar
I just found another clone for $160....
Mongoose JLR - Jaguar & Land Rover Dealer Level Diagnostics & Programming
Sounds way too cheap, and they even offer you a username & password.
That's a little too dodgy for my liking...
I actually bought one of those a couple of weeks ago after someone else reported that theirs worked. It came with a copy of IDS 129.01 and a username and password that Land Rover published to dealers for authenticating IDS v129 off-line. I suspect it therefore has to be run offline which is what I have done so far and is also unlikely to allow you to upgrade firmware without a subscription to Topix.
I had a bit of a battle getting it working but I think that was more to do with the software and Windows XP than hardware. I built a new virtual PC in the end and left it clean of anti-virus etc.
I have only had a quick play so far but it read the VIN automatically and all of the electronic modules and I was able to deflate and inflate the air suspension on my X350.
I also found a voucher code on the net to get another 5 or 6% off the list price.
Old Jul 24, 2012 | 09:01 PM
  #72
mrlovt's Avatar
I'm still getting tech help from China, but I would like to know how you got yours going. Would you mind sharing your experience with getting your Mongoose JLR working?
I have both IDS 127 and 130 with User IDs and Passwords, but I haven't been able to get them or Windows XP to recognize the JLR with either one. XP "hardware found" wizard says it can't find the drivers, and the SDD says that "The VCM is disconnected" even when it's plugged in. Device manager lists it as "Other Device" and "Mongoose JLR?CAN w/FEPS w/ISO" but says that the driver isn't installed.
Running 130, in SDD > System Informatin > Vehicle Communications Interface Status > Details it lists both VCM and MongoosePro JLR, but when I select the Mongoose and choose Device Configuration it never recognizes the device. Instead, it stops at "Gateway Device Selection Failed" "Configuration Failed".
So, I'm hoping someone more tech-savvy than I can help!
Old Jul 29, 2012 | 03:17 PM
  #73
03Xtype's Avatar
I also had issues until I got the drivers direct from drew tech.
Old Jul 29, 2012 | 03:22 PM
  #74
03Xtype's Avatar
So I finally got my scan tool completed. Later on I will post photos and info of my set up and what it cost me.
Anyways I was playing around with it and did a scan of my entire car in hopes of finding some old codes. At the end of the scan it looks like it saved the data to a file but didn't automatically open to show me a run down on the data, I'm not sure if I have an issue with my ids sdd or if I have to go to a different menu to get the file.
Can any one make a quick guide on how to do a general scan of the entire vehicle and see the data?
Old Jul 29, 2012 | 04:19 PM
  #75
xjrguy's Avatar
Tell us again..........exactly what setup do you have. Software, version and interface and version?
Cheers,
Old Jul 29, 2012 | 08:56 PM
  #76
03Xtype's Avatar
Cheers,
New laptop windows 7 pro 32bit = $390
JLR IDS v129 w/user&password = $280
Mongoose = $260
_______
$930
Old Jul 30, 2012 | 10:55 AM
  #77
xjrguy's Avatar
Mongoose = $260
_______
$930
When you say "did a scan", does that mean you found and ran the "Vehicle Scan" from the Recommendations screen?? If so, the file that "saved" is something that won't be of any value to you. What you need to see is what codes turned up in "Related Events", and also "Unrelated Events" tabs. Then there is a column that shows the module the code was pulled from, and the description of the code.
Be sure the Windows auto update is turned OFF! Operating system updates pose a great risk of causing problems.
Also be sure you have gotten the newest firmware and interface updater from DrewTech. That brings the interface up to the MongoosePro.
Good luck!
Old Jul 30, 2012 | 12:15 PM
  #78
03Xtype's Avatar
Good luck!
Thanks for the tips. I'm sure I was in the correct area with in the "diagnostic" section but got confused when I couldn't find any codes, I know I have a great running car but I thought there should be at least a few old codes to come up.
Old Jul 30, 2012 | 12:28 PM
  #79
avos's Avatar
Get the drivers from drew for the Mongoose JLR, not the MongoosePro JLR.
Old Jul 30, 2012 | 06:30 PM
  #80
xjrguy's Avatar
Why are you advocating that?? What do you have against using the updater and drivers for the MongoosePro??? That makes even an early device much more compatible.
Just curious.
