how to fit: zf 4speed 4hp22 auto on mk2 3.8?
Old Oct 9, 2015 | 08:12 PM
Stoney85's Avatar
Where in Australia are you?
I'd love to see some pictures of the setup you have gone with and what was required?
Old Jan 9, 2016 | 07:57 AM
hhroel's Avatar
Default HP22
Hi, it could be done by using an adapter plate, alloy or steel.
Problem is to center the thing otherwise judder ,
best remove the engine, than buy a good second hand auto box HP22.
Use the old Borg warner to make the adapter plate.
I made one for my Austin Healey, MK2 , BT7.
Reason for that is my handicap !
Good luck, Han.
Old Jan 9, 2016 | 01:24 PM
primaz's Avatar
Originally Posted by Peter Connell
The ZF box doesn't have a mechanical speedo take off. People I know who have done the conversion on V8 Rovers use the Dakota digital electronic drive.
Dakota Digital's ECD-100 Electronic Speedometer Cable Drive Unit - YouTube
The trouble is the cost.
Peter
Hey, we are Jaguar owners so we have deal with some cost I use the Dakoda digital as I am running a modern GM LS1 V8 so like all modern cars the output is digital and with that box it coverts it back to old school mechanical so I can keep my stock gauges. If you want to keep stock gauges then I think you need to spend the money otherwise change your gauges and you do not need the box. GM transmissions work well and there are so many performance transmissions available.
Old Apr 27, 2016 | 06:51 AM
MAURIE's Avatar
Hi again folks including Stoney 85.
I am in Victoria,you can get me on 0419 322 899.Iam not good at keeping photographic records,and although the assembly is now fitted and ready for start up a problem arose today,with fluid leaking from the transmission between the Volvo ext,n housing and g,box housing due to the head of a bolt fouling the inside of the ext,n housing.All fixed now,but it is suprising how many small differences there are in areas where you would think there would be interchangeability.
I have fitted a VDO electronic speedo but until the car is road going and the necessary setup procedure is complete I will not know how successful this will be.
Cheers for now.
Old Dec 23, 2016 | 11:35 PM
MAURIE's Avatar
Hi gents,340 is now on the road and performing very well,the zf4hp22 auto has transformed the car,with smooth almost undetectable gear changes and much quieter cruising.At 100 kph the engine does only 2000 rpm,it was not an easy conversion but well worthwhile.
Old Dec 24, 2016 | 03:02 AM
TilleyJon's Avatar
Hey guys as there are a lot of Auto guys on here can anyone help with this thread ?
https://www.jaguarforums.com/forum/m...lector-174171/
Old Dec 29, 2016 | 10:13 PM
lickahotskillet's Avatar
Default Here's some transmission conversion info
Transmission Conversions
from Vintage Jag Works
Vintage Jag Works
Old Dec 29, 2016 | 10:17 PM
  #28
Default more transmission conversions
Shop by Make - Jaguar - Transmission Kits
Don't know if any of these will work
Old Dec 29, 2016 | 10:30 PM
Default toyota transmission conversion
https://www.jaguarforums.com/forum/m...-build-133777/
From this forum
Old Jul 6, 2024 | 06:01 AM
  #30
alnoz7's Avatar
Hi Maurie- thinking about this conversion and discovered that you did it years ago - wondering if you are still on the forum as I'd like to run over your experience. I am in Victoria. Cheers Al;
Old Jul 7, 2024 | 01:52 AM
  #31
MAURIE's Avatar
Default Maurie
Hi Al sorry I have not been active on the forum of late but still actively involved in Jaguar restoration, mostly with V12's, but I still have the 340 so will help if possible.
I am placed in Melbourne . Cheers Maurie.
Old Jul 8, 2024 | 08:12 PM
  #32
Bill Mac's Avatar
If all else fails in trying to get a speedometer working, I suggest go for a GPS speedometer.
I have been using them for years in addition to normal speedos.
They are far more accurate than any mechanical or electric system fitted to the majority of cars.
The only problem is they don't work in tunnels.
DFW
Jul 27, 2020 02:44 PM
Rocky15
Oct 12, 2015 03:42 AM
JungleJonny
Oct 5, 2015 03:52 PM
k-man
Oct 5, 2015 08:09 AM
