2005 jaguar VDP Differential
Old Sep 2, 2013 | 11:36 PM
dreyco86's Avatar
Default 2005 jaguar VDP Differential
I have a leak out of the bearing on the driver side of my differential, along with a quiet humming noise while driving. Can someone tell me what kind of bearing I need to buy? I've searched the net and I found some from the $14-$40 range and then another kind of bearing for just under $400. What kind do I need? Inner or outer? Do I need a seal too?
Old Sep 3, 2013 | 02:19 AM
Welcome to the forum dreyco86,
Good to have you here with us at Jaguar forums. Sorry to hear about the diff issue. It might only be a leaking seal and low fluid so check with members in the X350 tech section for parts and procedures.
Follow this link https://www.jaguarforums.com/forum/xj-x350-x358-xj6-xj8-xjr-28/ to the X350 section for help, advice and information.
You can also visit the US Northwest Region section by following this link https://www.jaguarforums.com/forum/northwest-washington-oregon-idaho-sw-canadians-64/
Old Sep 3, 2013 | 05:57 AM
Old Sep 3, 2013 | 06:30 AM
welcome to the forum - plenty of info and support here - by far the best tool in a Jag owner's tool box. Hope you can get your issue resolved in short order so you can enjoy driving her again
Old Sep 3, 2013 | 07:36 PM
Hey there and welcome aboard....... good to have you here with us here at Jaguarforums
If you need any further help with the site, please just ask any moderator, veteran member and we'll be glad to assist.
In the meantime, any useful site information you may need such as how to post pictures, edit signatures, add videos, using the search
facility etc, can be found here within the following link
Helpful_information
See you in the forums....
Old Sep 3, 2013 | 08:00 PM
Cambo's Avatar
Welcome to the forum dreyco!
The diff seals are available to buy from Jaguar (the ones that seal to the outside of the diff case) but the bearings are not.
I recently had the diff in my 2005 XJR rebuilt (at the same time as fitting an LSD) and I bought a bearing & seal kit from the supplier in the UK who sold me the LSD.
Unfortunately I didn't write down the part numbers of the bearings, I only took a photo...
You can see the part numbers for the seals on the bags, there are four bearings, 2x from Koyo, 1x from Timken and the other came without a box...
The Koyo ones are for the sides of the diff center, the Timken and other are for the pinion.
Try contacting TL Jaguar or Racing Green in the UK. I also remember seeing a website of a company in the US that fitted a Quaife to an X150 XKR (has the same diff) and they found the bearings needed.
Old May 16, 2014 | 04:54 PM
Zvonas's Avatar
Hi any news with part numbers? Thank a lot!
Old May 16, 2014 | 06:05 PM
Cambo's Avatar
Hey Pavel,
The bearings were identified as generic Ford bearings, same as the Lincoln LS and a few others.
The part number for the bearings is in this thread https://www.jaguarforums.com/forum/x...arings-102296/
I got your message on the other forum, please go to this thread https://www.jaguarforums.com/forum/g...ids-sdd-77299/ and continue the discussion there, very interested to know how the ratio swap went, and if your guy will be able to reprogram the ZF transmission, he's not in Bulgaria is he?
Old May 17, 2014 | 06:20 PM
Helpful_information
Old May 19, 2014 | 04:16 AM
Zvonas's Avatar
Hey Pavel,
Thanks, I've finally found the numbers and will update that thread. The guy is in Czech Republic.
Old May 19, 2014 | 04:55 AM
Cambo's Avatar
Very keen to see how this turns out!
BrentGardner
29
Dec 16, 2024 12:13 AM
plums
General Tech Help
Sep 1, 2015 06:34 AM
mrplow58
Aug 29, 2015 10:44 PM
DeaconHull
Aug 28, 2015 05:26 PM
divingmom
Aug 25, 2015 07:54 PM
