Engine swap
Old May 14, 2012 | 03:14 PM
james henry's Avatar
Angry Engine swap
Hello all jag lovers, my name is james and I own a 2000 xjr supercharger. I recently bought a 98 xjr replacement engine under the advice of a machanic telling me that it will fit my 2000 xjr, well it fits but the cam sensors does not match up. Can some one please tell me how to rectify this problem or call me if you have a used 2000 xjr engine for sale or let me know a good place to shop for one. thank you so very much, James in Tacoma, Wa.
Old May 14, 2012 | 07:13 PM
Hi James n welcome to Jaguarforums, good to have you here with us
share some pics when you can..............
In the meantime I've manually upgraded you to full forum access so you can better view the whole site and all its features
Jump on in and enjoy
Old May 14, 2012 | 08:17 PM
Welcome to the forum,
Head over and ask in the tech section.
Old May 15, 2012 | 07:33 PM
thank you
Old May 16, 2012 | 02:23 AM
Welcome to the forum.
Good to see you.
Maybe edit you location to be a little less specific.
Best of luck with your swap problem.
Old May 16, 2012 | 03:34 AM
avos's Avatar
Welcome to the forum!
If you create a post in the right section as mentioned, I or others can already give you some good advice, as not all parts can be swapped over between different engine years.
Old May 19, 2012 | 07:31 PM
jagdayn's Avatar
welcome to the forum. i used car-part.com to find the engine for my 95 xjr. good luck with the swap!
Dayn.
Old May 19, 2012 | 09:40 PM
motorcarman's Avatar
It is easier to go from AJ26 to AJ27 as the CMPS is missing from Bank 1 in the cylinder head. The cams are different (1 AJ26 CMPS lobe vs 4 for the AJ27) You can leave the CMPS disconnected from that bank but drilling a hole and locating the sensor might be difficult.
I have posted a story about a customer that did the AJ27 to AJ26 swap but did not disclose all the details until I was well into the diagnosis.
The torque converter drive plates with the CKPS reluctor segments are also different.
Good luck with the swap.
bob gauff
Old May 20, 2012 | 12:28 PM
queenmb's Avatar
Smile Welcome
FrickenJag
Jun 16, 2025 02:15 PM
cissdm
May 3, 2016 06:02 AM
sogood
Sep 15, 2015 07:35 AM
bdboyle
Sep 4, 2015 06:16 AM
Bowman
Sep 3, 2015 03:17 PM
