new to jags serpentine problem
Old Feb 12, 2014 | 07:50 PM
gogurt92's Avatar
Default new to jags serpentine problem
Hello everyone. I'm new to jaguars. I bought myself a 1998 Xj8 and I'm really happy with it. I'm finally having some trouble with it. I purchased her this summer.
My serpentine belt tore a bit along the edges and came off. I then just replaced it thinking it was just old or something. Turned the car on and it ran perfectly for about a day. Then on my way to work it slipped off again. It didn't break or tear, it just slipped off.
Put it into the garage and started to diagnose the problem. Rerouted the belt again, started the car and it slipped off again (right by the idler) and the new belt tore just like the old one. Figured it was a bad tensioner because the belt wasn't as tight as i though it should be. I bought that, and i also went ahead and bought a new idler pulley because that is where it kept slipping off.
Once i had all my new parts we rerouted the new belt. I turned the engine just by flicking the key a little so it wouldn't fully start because i didn't want to risk breaking another belt. My pops was watching the belt while i was turning the key and he could tell the belt started to slip in the same place, right by the idler pulley.
Stopped to make sure everything was routed correctly, which it was. We were also able to move the belt back into position by hand as if the belt wasn't tight enough. We are sure it is the correct belt. The tensioner and the pulleys are also the proper parts, so I'm ruling that out.
We stopped there so we could do some more research on how to try to fix the problem. Could I please get some information for someone if they've had this same problem in the past?
Old Feb 12, 2014 | 09:08 PM
Bad Cattitude's Avatar
Welcome! Sounds like something is mis-aligned. Check the component pulley that the belt runs right before it gets to the idler.
Old Feb 12, 2014 | 09:17 PM
gogurt92's Avatar
that would be the alternator. Ill have to give that a look when i get back out there tomorrow afternoon, THanks!
Old Feb 13, 2014 | 02:57 AM
Welcome to the forum gogurt92,
There's only 3 things can go wrong with the Serpentine Belt:
1. wrong belt
2. routed wrongly
3. damaged pulley or tensioner
You should not be able to move the belt by hand because there is a lot of tension on it.
Follow this link XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum to the X308 forum for help, advice and information.
You can also visit the US MidWest Region forum by following this link Mid West US - IL IN IA MI MN MO OH WI - Jaguar Forums - Jaguar Enthusiasts Forum
Enjoy the forums.
Old Feb 13, 2014 | 07:13 AM
Welcome to Jaguar Forums gogurt92,
Old Feb 13, 2014 | 07:24 AM
Schwabe's Avatar
welcome and enjoy the board
Old Feb 13, 2014 | 07:28 AM
welcome to the forum - there is plenty of info and support here simply follow the links Graham has provided - enjoy
Old Feb 14, 2014 | 08:22 PM
search facility etc, can be found here within the following link Helpful_information
Old Feb 18, 2014 | 03:26 PM
gogurt92's Avatar
does anyone know the part number for the serpentine belt for the 98 xj8 base model. Auto zone gave me the belt with the number 7pk2325 and its been slipping off. I compared it with the old belt and its longer.. the old belt number says 7pk2327put the old belt back on the has some chunks taken out of it and sure enough it didnt slip off. Can anyone verify that the oem part number is 7pk2327?
Old Feb 18, 2014 | 04:15 PM
SNG Barratt USA's Avatar
Former Sponsor
NCA2211DA
See link below:
www.sngbarratt.com/CatalogueProducts.aspx?m=43&c=3197&s=12291&a=12290
Rutty
XJ40 ( XJ81 )
Jan 10, 2019 09:47 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
jagy4321
Sep 3, 2015 07:56 PM
nelsonht
Aug 30, 2015 06:01 AM
