Please help!
Old Mar 11, 2020 | 01:46 AM
hambrightjason92's Avatar
Question Please help!
I recently purchased an 02 Jaguar X-Type 3.0 from a car auction. When I drove off with the vehicle, i noticed the car had an engine light on. Half way down the street i noticed it started flashing gearbox fault light on the dashboard. Once I got the vehicle home, We used an OBDII scanner to diagnose the issues. Upon scanning the car, it showed many codes such as p0057, p0735, p1582, p0304, p1314, p1316! I became immediatley discouarged!! I took the vehicle to a shop because I knew the owner thru my place of work. He began to lay the bad news on me and he said besides a basic tune up which would be close to 500, It would also need a new transmission. I drove the car home and began doing research on the vehicle. I began to try and address the issues that were in my control, such as a drain and fill of transmission fluid and I replaced the o2 sensor in the Bank 2 lower 2. Once we did that, the issues that are still showing are the Gearbox fault light on the dash and the engine light will show once i drive the vehicle. We plugged the scanner back in and the only code that shows now is that P0735 which is a gear 5 incorrect ratio. From my research here on the forum, Ive noticed nothing good comes from that code. From what i gathered, They all recommend replacing the transmission..... At this point, I really do NOT want to replace that transmission, what shall I do?!?!
Sidebar, I have noticed there is a click noise that sounds every time I release my foot from the brake pedal... I have gathered that it is just an annoyance instead of an actual issue. I have also gathered the J gear shifter could be an issue that can cause the gear box fault light to show... As you can see I am really stuck in between a rock and a hard place!! Please give me some advise as the vehicle needs to be registered by this month and I am pretty sure I will need to complete a smog check as well.
Old Mar 11, 2020 | 02:24 AM
Welcome to the Forums.
OOPS
I assume an AUTO trans??. If so, maybe a few (4) drop and refills will help, maybe not, did with mine.
The X Type (X400) Tech Section will have better, and more, answers.
Good luck.
Old Mar 11, 2020 | 03:03 AM
Welcome to the forums hambrightjason92,
I've copied your post to X-Type forum for advice from members with the same model. Here's the direct link to it:
https://www.jaguarforums.com/forum/x...0/#post2202487
Follow this link https://www.jaguarforums.com/forum/x-type-x400-14/ to the main X-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the US Western Region forum by following this link https://www.jaguarforums.com/forum/us-western-38/ to find other members in your region.
Old Mar 11, 2020 | 03:53 AM
Daf11e's Avatar
Welcome aboard.
Old Mar 11, 2020 | 04:43 AM
Welcome to Jaguar Forums hambrightjason92,
Last edited by GGG; Mar 11, 2020 at 05:32 AM. Reason: Remove link to X100 forum thread
Old Mar 11, 2020 | 07:14 AM
welcome to the forum
Old Mar 11, 2020 | 09:11 AM
Hello,
I'm sorry your new Jaguar has turned out to be such a disappointment. I hope you can get most of these problems resolved relatively simply.
Old Mar 17, 2020 | 12:12 AM
o1xjr's Avatar
Welcome to the forums.
Freebob
Feb 4, 2020 01:34 AM
Jaquar2003
Jul 2, 2019 08:21 AM
William Wells
Jul 7, 2017 07:25 PM
Supermill
Apr 7, 2017 11:33 AM
jpc823x
Aug 25, 2014 10:51 AM
