4.0 radiator overheating
Old Feb 27, 2013 | 01:45 PM
texmanmoore's Avatar
Default 4.0 radiator overheating
Im having an issue with my 2001 s type 4.0 , years ago my wife learned a hard lesson when the plastic overflow tank cracked drained out the fluid and melted down the engine. She never noticed the temp gage. I had to replace the engine, no problems for years until recently.Engine overheats within 5 miles of driving. , no leaks. What could be going on ? engine has 85K miles , Do these engine have issues with sticky themostates ? of failing closed ? What about water pumps I m thinking its good but havent investigated yet.
The temp gage gets hot very fast, making me wonder if water isnt flowing past the sensor. I would not think the raditor would be plugging. Im looking for your all's input? Or what you all think ?
Old Feb 27, 2013 | 02:35 PM
bfsgross's Avatar
Scottyyyyy! (Dr. Evil to his son Scotty in Austin Powers's Gold Member). Yes, the thermostat is likely the culprit. It's easy to change, then you're on your way.
Old Feb 27, 2013 | 05:41 PM
Default thx Dr Evil , i think that is very good advise
UPDATE UPDATE, on my drive home from the overheating this morning. I think i avoided the HIGH temp or overheating by turning the Heater on high, This is a 10 mile trip, when i got about 2 miles from home i turned the heater OFF. Within minutes the Temp gauge started rising. Giving me more confidence that the thermostate is sticking or stuck closed. I'm hearing this is common , Can i get more of you to give me your input or thoughts ??
I also noticed a noise near the water pump area while the engine is running ? Do the water pumps fail very often. Are they hard to change out ?? Im assuming the water pump is located behind the upper pulley on the engine ? Thanks you for your advice!!!
Old Feb 27, 2013 | 06:10 PM
GoKittyGo's Avatar
I'm looking forward to see the replies you get, I'm having a similar but different issue..
Old Feb 27, 2013 | 06:29 PM
WhiteXKR's Avatar
I agree...start with the thermostat.
A couple of points relevant to your comments:
1. As you painfully found out, when the coolant gets very, very low, if drops below the temperature sensor and may not give an overheat warning. That is why it is critical on these cars to have a functioning low coolant warning and never to ignore it.
2. The temperature gauge will sit at center scale from about 185 F to about 230 F. Unfortunately this means you will not see the real temperature until you are nearly overheating! This is the reason for the sudden rise of the needle if your thermostat sticks.
Old Feb 27, 2013 | 08:34 PM
bfsgross's Avatar
Scotty, I wasn't friggin kidding when I suggested changing the thermostat. LOL!. Just kidding. Seriously, it's cheap and easy to perform the swap. It's rare for an S-Type water pump to fail. Jaguar uses premium grade pumps.
Old Feb 28, 2013 | 01:49 AM
JagV8's Avatar
Was it the 4.0 that has water pump blades that occasionally break off?
Old May 9, 2017 | 04:00 PM
Mwilliams's Avatar
Default 2001 s
Have changed three water pumps and the thermostat. Air conditioner probably could use some more coolant. Do oil changes and filter change every 3000 miles. Still having consistent problems with overheating in less then 2 miles from home!
Old May 9, 2017 | 08:26 PM
motorcarman's Avatar
Radiator cooling fan????
Blown head gasket???
Air lock in cooling system??? Bleed procedures are different for the V6/V8
What mystery car do you have???
You should start a post of your own. Digging up a necropost confuses the issue.
Welcome to the forum.
bob
Old May 9, 2017 | 09:30 PM
abonano's Avatar
My opinion is either a stubborn air pocket or your water pump is either toast or on its way out. I disagree with the thermostat being stuck closed as if that was the case turning on the heater would have little to no effect keeping the engine coolant at temp.
You must also check the plastic thermostat housing for cracks or internal failure (broken plastic fins internal at the thermostat)
aode06
Jul 28, 2023 02:26 PM
mikiep
Dec 20, 2019 07:37 PM
vwbusbits
Oct 13, 2015 03:43 AM
bydand
Sep 28, 2015 09:47 AM
bydand
Sep 27, 2015 12:00 PM
