ABS/TC lights on
Old Aug 5, 2019 | 08:55 AM
Coops5863's Avatar
Default ABS/TC lights on
Good afternoon all my S type has the abs and tc lights I have a icarsoft 930i scanner which read a fault to the O/S/R speed sensor I have replaced the sensor 2 times now along with the abs mouldle I have checked the abs loom all connectors are clean still I have the 2 dash warning lights on abs and tc any body had the same fault and knows how to fix the problem without it fixed I am unable to get a new MOT
Old Aug 6, 2019 | 07:31 AM
aholbro1's Avatar
A flat battery sometimes sets those.....
Old Aug 6, 2019 | 11:41 AM
S-Type Owner's Avatar
When you changed the ABS sensor, did you check/clean the toothed reluctor ring as well...?
Old Aug 6, 2019 | 05:37 PM
Coops5863's Avatar
Yes I removed both drive shalfts from the vehicle and inspected both reluctor rings both are intact and clean I have replaced the battery my next move is to check all the abs loom from under the back seat for complete continuity
Regards Glenn
Old Aug 6, 2019 | 05:57 PM
kr98664's Avatar
Have you charged this new battery? Typically, new batteries are not fully charged when purchased.
These cars are very sensitive to low prestart voltage. No guarantees this is the problem, but it’s free and easy to rule out.
Old Aug 6, 2019 | 06:12 PM
Coops5863's Avatar
Hi yes the battery is charged reading high on the battery volt tester
I am going to check the rear ABS wiring looms with a muilty meter I have taken out the rear seat so far the rear ABS loom looks OK my 2001 S type has 1 large muilty plug clipped on the rear subframe and loom from that plug goes inside the car under the back seat my next step I think is to check the abs wires for the o/s/r abs/speed sensor for continuity hope this gives me the answer
Regards Glenn
Old Aug 24, 2019 | 05:28 PM
Chuck Zalinski's Avatar
I just replied to this same issue on another thread. A pretty common problem and if I were a gambling man I'd give you 4 to 1 it is the ABS module.
My 2002 XJ8 had it and I fixed for about $55 and a couple hours work.
Here is a YouTube video
I removed the module myself. I did not disconnect the brake lines because you can work the module free without disconnecting the brake lines. Then I shipped the module to a repair shop in the LA area that will fix the module and send your same module back. $45 plus $10 for shipping. Done end-to-end in about 10 days. I found them on eBay.
Old Aug 25, 2019 | 09:34 AM
Aarcuda's Avatar
check for corrosion on connectors
annamiata
Dec 8, 2019 02:56 PM
charger12
Apr 4, 2012 04:23 PM
babbah
XJ40 ( XJ81 )
Sep 14, 2010 04:58 PM
