auto gearbox problem
Old Jun 25, 2014 | 02:31 PM
omoledstronger's Avatar
Default auto gearbox problem
my jaguar s type 2003 model v6 is having a real gear problem. i noticed dat d gear push to change while accelerating. from gear 3 to 4. and once am accelerating nd match d brake pedal once it stops the gear also jerk. and dis trigal abs fault. i will appreciate any assistance on dis problem pls. help me out.
Old Jun 25, 2014 | 05:11 PM
Cambo's Avatar
Yours being a 2003 model, it has the 6-speed transmission?
Old Jun 25, 2014 | 05:48 PM
no. its 5. any help?
Old Jun 25, 2014 | 05:53 PM
Cambo's Avatar
OK 5-speed is the Ford 5R55N transmission. And if you're having issues with shifting 3-4 then it's probably the prestroke spring.
Have a look here https://www.jaguarforums.com/forum/s...acement-22929/ and https://www.jaguarforums.com/forum/s...ild-faq-48240/
EDIT
Are you sure it's a 5-speed? What are the last six digits of the VIN? Higher than M45255?
Old Jun 26, 2014 | 04:43 AM
police666's Avatar
are you sure it is the 5 speed ?
do the numbers on the j gate go to 5 or 4 ?
if it goes to 5 you have the 6 speed
if it has an electronic parking brake you have the 6 speed
if the numbers go to 4 you have the 5 speed
Old Jun 26, 2014 | 02:00 PM
so sorry. its 6 speed. and d last 7 digit num is JM71309. jaguar s type 2003 model. the major problem is that jerking like someone hit me behind if i am accelerating and i match pedal brake to stop it jerks before it comes back to park. i will appreciate your quick response and assiatance.
Old Jun 26, 2014 | 03:53 PM
JagV8's Avatar
Well, it can be an engine fault or "the lurch" (Search / google for it).
Oh - or a power (battery etc) fault.
Engine fault would include running OL (open loop) due to some sensor or the like not working or maybe an air leak. OBD would let you check it's not OL / air leak / etc.
Old Jun 26, 2014 | 04:57 PM
police666's Avatar
If it is a form of the lurch some people have found having the box adaptations cleared has cured it.
I'd make sure engine and battery are perfect and have fluid level checked
Old Jun 28, 2014 | 06:59 PM
ok. thanks for the message. but does car lurch triger abs fault? pls help me out.
Old Jul 3, 2014 | 08:30 AM
police666's Avatar
No it doesn't.
Abs fault can be sensor, reluctor ring, bad battery, wiring, bad module....... The list goes on, what's the exact code
Wolfy
May 28, 2024 08:06 AM
cissdm
May 3, 2016 06:02 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
pnwrs2000
Sep 3, 2015 11:55 AM
