aux heater water pump?
Old Jan 30, 2016 | 07:14 PM
Kewpie's Avatar
Default aux heater water pump?
My son and I were replacing the dvvc, it was packed with what looks like mud. So were some hoses. The aux. water pump is all chewed up, the electric part is frayed/melted. Where can I get a new one of these? Looking all over, can't find one
Old Jan 30, 2016 | 08:13 PM
Kewpie's Avatar
Only auto parts store that I could find online that carries one is oreilly's. Called several oreilly's, they can't find it on their website. I told them I am looking at it on their site, part #5w-8005. they can't find it. What a mess.
Old Jan 30, 2016 | 08:22 PM
Kewpie's Avatar
OK, found a new and used one on Ebay, wanted one now. Oh well, I also need the pigtail that plugs into the pump, it is melted. Any ideas?
Old Jan 30, 2016 | 11:26 PM
abonano's Avatar
EBay for both. Make sure you get the right aux pump as they are different on the SC and norm aspirated V8's
Old Jan 31, 2016 | 02:55 AM
car5car's Avatar
del
Old Jan 31, 2016 | 07:54 AM
Kewpie's Avatar
Deleting it is an interesting thought, since the part cost 116.00. Anyone else tried this?
Old Jan 31, 2016 | 08:09 AM
Kewpie's Avatar
this is a link to the cardone part
Cardone Select 5W8005 - Auxiliary Coolant Pump | O'Reilly Auto Parts
Old Jan 31, 2016 | 09:33 AM
JagV8's Avatar
Deleting it on the STR would be "brave". Any overheat will be fatal.
Old Jan 31, 2016 | 10:09 AM
abonano's Avatar
Extremely brave indeed. I would highly advise against it...
Old Jan 31, 2016 | 05:14 PM
Ragn0r's Avatar
Default Auxiliary Water Pump
Replaced the one on my 2007 Jaguar S-Type R with no issues.Engine Auxiliary Water Pump Dorman 902 407 Fits 01 03 Dodge Durango | eBay
Old Feb 1, 2016 | 01:05 AM
car5car's Avatar
I deleted my post, I am pretty sure I removed heater core pump on my Catera, not engine cooling pump.
Old Feb 1, 2016 | 12:35 PM
tbird6's Avatar
I put a factory pump in. Who knows what that Dodge pump is rated at even if it fits?
Old Feb 1, 2016 | 12:55 PM
Kewpie's Avatar
dodge one looks exactly like the ford one. don't know if the rate is any different
Old Feb 1, 2016 | 01:08 PM
tbird6's Avatar
That's my point.
Old Feb 1, 2016 | 07:28 PM
Ragn0r's Avatar
Thus far (1000 miles) all indications are that the Aux Pump that fits Dodge Durango is on par with the OEM pump that was replaced.
Old Feb 1, 2016 | 07:55 PM
davidladewig's Avatar
OOOOOOOOOOOOK!. I'll ask the dumb question of the night. How do you know if the pump is running or not?
Old Feb 2, 2016 | 03:25 AM
Ragn0r's Avatar
You get heat through the vents when the engine is at idle for extended periods or off when the coolant is still warm.
Old Feb 2, 2016 | 03:32 AM
JagV8's Avatar
I'd probably use a meter (DVOM) at the relay shown in Electrical Guide
Old Feb 18, 2016 | 04:37 PM
65 bu's Avatar
Default Aux pump opperation requirements?
I am a professional European wrench, I have an 06 S-type R. The ECM doesn't send ground signal to the control side of the relay (R7 in the engine compartment fues/relay center). I have parused all of the information available to me on AllData, Mitchell 1, and cannot find any description of the conditions for aux. pump opperation. Any ideas where to find this information. If you can piont me To it, I will take it from there. By the way, I've already tested for relay activation at the ECM, I got bupkis. All other Circuit integrity is good ( fuses, connections, wires, pump motor, continuity to the ECM, etc.)
Old Feb 18, 2016 | 05:15 PM
JagV8's Avatar
If you mean the aux coolant pump then it's not the "ECM" but the ACCM aka CCM (or RCCM in many cars), I think.
It's an unusual pump to be checking. Did / does the car have a heating problem? It's usually related to the DCCV and that often damages the RCCM.
It's possible you're looking in the wrong places.
chillyphilly
May 19, 2020 01:37 PM
phu5ion
Feb 9, 2016 02:22 PM
Hafrod
Jan 30, 2016 10:34 PM
Brian BigSkip Skipper
Jan 27, 2016 02:35 AM
