Bought Jag 05 model knowing trans is my on codes show P0729
Old Feb 3, 2019 | 08:11 PM
james smoot's Avatar
Default Bought Jag 05 model knowing trans is my on codes show P0729
Just bought yesterday.
I knew trans was shifting out of 3rd. I was thinking of getting a valve body with shifting solonoids installed. Do my own service when I can. Had codes read and cleared. Drove half mile they came back. Improper ratio 3 to 4, 5.6 not at all working. Fluid change showed nothing.
thank yall
____________
2005 S-Type 4.2
(added by GGG)
Old Feb 4, 2019 | 03:25 AM
Welcome to the forum James,
I've moved your question from New Member Area - Intro a MUST to S-Type forum. Members here with the same model will be able to help.
Old Feb 4, 2019 | 09:07 AM
To get the discussion started, here's the Jaguar decode for P0729:
Old Feb 4, 2019 | 03:20 PM
abonano's Avatar
thank yall
____________
2005 S-Type 4.2
(added by GGG)
I hope you bought it real cheap as a replacement trans is more than likely in your near future.
Based on your description it is likely your E Clutch is toast. Replacing the valve body/solenoids will not rectify.
A few things to check on...
1) Is there any leakage/seepage in the TCM rubber sleeve. Is the TCM harness connector wet or damp?
2) Was the fluid topped off correctly. Dribble at 40 deg C then cap off?
3) When you drained the old fluid did you get 6 - 7L out?
4) Any seepage at the trans cooler lines? Pan??
If the trans was low on fluid (more than 2L) time to source a replacement unit as these rebuilt go between 5 - 7K at a trans shop.
You could also get the adaptions reset and flash the TCM but it sounds mechanical in nature.
These units are pretty good until they run low on fluid.
Good Luck
Old Feb 4, 2019 | 04:18 PM
Default I didn't do t
Good Luck
E previous owner had it done so not sure on all that was thinking trying to rebuild watched video on it no can do lol place n dallas tx. Sells around 1500 with warranty yr i believe yes I stole it waited 6 weeks he came down to what I wanted to pay it is primo for 15 yrs old garage kept drove it home 40 mph @2800 rpm didn't run hot even if 1500 to replace tyranny still a bargain ty for responding read a lot of information on here battery is tested shows good. Gonna hv to get a new obd reader too my 40$ doesn't wanna talk jag codes appreciate y'all taking time for advice. I'm 62 and still wrenching some me n the cat prepare for battle thanks guys!!
Old Feb 4, 2019 | 04:38 PM
Busa's Avatar
Sounds fun if you have the facilities.
Please keep us informed?
Old Feb 4, 2019 | 07:16 PM
Ty sir
Old Feb 4, 2019 | 07:23 PM
Will do I'm positive I 'll b back b checking tcm fluid level n such. Ty
Old Feb 5, 2019 | 07:27 PM
Default thanks all
Good Luck
found the tcm take down tomorrow ordered7 ltrs fluid and pan be here n wk or so sorry for misspelled and all doing this on phone lol ty very much for the help will keep y'all updated !!thanks again
Old Feb 6, 2019 | 02:20 AM
Ducmon's Avatar
This video shows you how to do it correctly.
https://youtu.be/MAMseFY8GpY
Make sure that your torque wrench can go that low or you may break the the New filter.
Here is the manual if you don't have it already
http://jagrepair.com/images/AutoRepairPhotos/CarPDFFiles/SType/S-Type%202002.5-2008-FSM-Workshop.pdf
Old Feb 7, 2019 | 12:13 PM
Default thanks all
Is there a manual on DVD format? The owners manual cd was not in the car.Mr Haynes hasn't helped so I'm shopping for DVD . thanks for the welcome from everyone.sure helps surrounded by knowledgeable people!!
Old Feb 7, 2019 | 01:12 PM
Ducmon's Avatar
If you look at the post above your last one you will see a link to the manual.
Old Feb 7, 2019 | 08:15 PM
Default thanks bff ducmon.awesome info .sure appreciate y'alls help !!
Great group glad to be apart of!
james smoot
Feb 16, 2019 02:54 PM
Acethomas
Sep 21, 2014 04:55 PM
zbodyworker
Aug 27, 2012 06:28 PM
fhowell
Mar 26, 2012 04:03 PM
Oct 2, 2006 10:15 PM
