CATS System Fault
Old Oct 28, 2012 | 05:13 PM
clmajak's Avatar
Default CATS System Fault
My 4.0 S-Type 2001, has a error message for a CATS System Fault. Does not look as if there is any damage to the wires to the front shocks. Is there a way to reset this? Tried to reset by unhooking the modules in the trunk, no effect.
Old Oct 28, 2012 | 07:27 PM
bfsgross's Avatar
To re-set the CATS module disconnect both the neg. and pos. terminals from battery and touch them together for 30 seconds. This'll also "hard re-set" the ECU.
Old Oct 28, 2012 | 07:37 PM
abonano's Avatar
To add - if you continue to get the CATS fault message after the hard reset - test your battery. If the battery checks out as good - you will need to get to the root cause of the CATS issue - did you check the wires/connectors on the back shocks?
Old Oct 28, 2012 | 07:45 PM
Gus's Avatar
Gus
Forgive me but I did not think you could clear codes using the hard reset.
Old Oct 29, 2012 | 02:19 AM
JagV8's Avatar
Generally you can only clear codes in the PCM (aka ECM) that way. Maybe the CATS module too? I'm unconvinced, though.
They'll probably self-clear when the fault is fixed...
Old Oct 30, 2012 | 02:25 PM
Tijoe's Avatar
Are you getting the little orange light next to the mileage indicator lit up, along with a fault in the mileage box that says “CATS System Fault”? My Car started getting this fault about a month ago.
Based on reading all the posting on the forum this is what I had to do to fix my system.
1. Check for water/moisture in the spare tire area. (I had water in the trunk.)(There are many posting about water in the trunk leading to electrical problems.)
2. The CATS control module is located in the trunk next to the spare tire closest to the rear bumper on the driver side of the car.
3. Remove the electrical connector and inspect for broken and/or corroded wires. (Apparently if you get water in the trunk area, the moisture quickly corrodes the connectors to both the back-up sensor module and the CATS control module.)
4. In my case corrosion on the power wire caused the main power wire to break off the connector pin.
I would check for this type of problem first before blaming other things in the car.
Old Oct 30, 2012 | 08:57 PM
motorcarman's Avatar
Tijoe is correct about the 'water in the boot' issue but if there is an actual fault in the system then you need to read the faults before replacing part indiscriminately.
The module is on the SCP network and will have DTCs logged.
What codes are in the module???
If no communication then it could be the module or connections failed.
The rear dampers are also CATS so they might be at fault?????
bob gauff
Old Jan 4, 2016 | 01:25 AM
NomisJAR's Avatar
How can you locate where the water in the boot in getting in from?
I discovered about an inch of water in the back and recently after a bad rain for 2 days both reverse assist and CATS are messed up.
Old Jan 4, 2016 | 01:26 AM
NomisJAR's Avatar
Old Jan 4, 2016 | 01:54 AM
JagV8's Avatar
Get in with torch (flashlight) / try talc / flour. Someone outside with hose.
cissdm
May 3, 2016 06:02 AM
Safari
Sep 14, 2015 10:29 AM
tonyforman
Sep 10, 2015 07:23 PM
1100me
Sep 7, 2015 06:26 AM
