DSC Warning light came on
Old Jun 28, 2014 | 07:29 PM
KCooper167's Avatar
Default DSC Warning light came on
In the midst of trouble shooting one problem, (engine noise from front part of the engine (serpentine belt?) a new one emerged. After cleaning up the engine compartment with degreaser and a low pressure water hose, I started the engine and let it run for a few minutes. A few hours later I returned to take her out but she wouldn't start. Lots of lights and clicking but no starter turning. I immediately checked the battery and it was right at 9 volts. I suspect I ran the battery down a bit while working on it for the past few days. I charged the battery for an hour and rechecked. She started right up but now I have a DSC NOT AVAILABLE WARNING LIGHT. I charged the battery until it was fully charged and the car starts fine but the DSC light won't go out. Any ideas on how to fix this. Also, the switch on the dash doesn't seem to turn the DSC on or off should there be an indication that DSC is activated?
Old Jun 29, 2014 | 06:49 AM
Jon89's Avatar
These cars detest low batteries and throw all sorts of spurious codes and messages when their batteries begin to die. Yours is probably beyond repair....
And be careful when washing the engine bay. The throttle body and spark plug wells will bite you given just the slightest bit of moisture residue....
Old Jun 29, 2014 | 08:00 AM
JagV8's Avatar
Probably need 8 hours or more on a charger to recharge if you haven't killed the battery. They hate being dropped to low levels.
Old Jun 29, 2014 | 10:42 AM
Mikey's Avatar
+1!
Never take a hose to an engine or engine bay.
Old Jun 29, 2014 | 11:28 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
The ABS Fault/DSC Not Available message may clear itself as mine did yesterday after a few trips around town.
Old Jun 29, 2014 | 01:59 PM
KCooper167's Avatar
Smile DCS Warning Light Came On....Update
A huge thanks to all that replied to my plight. While waiting for a solution to my problem, I read back through many (8-10) pages of the forum. I saw my warning msg in many of those related to a discharged battery. So, I charged my battery overnight using a commercial grade battery charger and tester. My battery checked out as "OK" so I attributed the discharge to the many hours I had the doors open, running windows up and down, trunk open, listening to the radio while waxing, etc. Of course. washing the motor didn't help. But after disconnecting, cleaning and reconnecting every connector I could find under the hood, as well as cleaning the battery posts, I thought I had done everything I could do. This morning, she started right up...no warnings. After a 45 minute spirited drive down the freeway, everything worked as it should and no messages. Now to get back to the belt change....Thanks again!
P.S. is there a procedure for changing the battery? I plan to pickup a new battery and install myself.
Old Jul 21, 2014 | 06:28 AM
Texascherokee's Avatar
Mine is on flashing 2000 4.0 ? Says sensor in steering wheel ?
Old Jul 22, 2014 | 05:56 AM
KCooper167's Avatar
Default DSC warning light
Hi from Pearland. Have you had any battery issues lately? I had the same code after washing the engine and running the battery down. As stated earlier, these things hate low/weak batteries. Once I replaced the battery with a new one and cleared all codes (I had several including yours), all was well. It's been several weeks now and no returning codes (and no washing the engine). Check your battery and if any doubt, replace. My old battery was less than a year old but purchased at one of the "box" stores (read cheap) and just wasn't up to the task of keeping up with the Jag's electrical demand. Hope this helps.
99xk8guy
May 28, 2024 09:36 PM
D.K
Dec 10, 2023 02:05 AM
Jpav27
Jul 31, 2022 06:43 AM
simo5555
Sep 9, 2015 06:22 AM
edtexas
Sep 4, 2015 08:20 PM
