engine shakes on idle. coils?
Old Jul 3, 2007 | 07:33 PM
kiloslanga's Avatar
Default engine shakes on idle. coils?
hello fellow jag owners im new to this forum. have a 02 jag s type 4.0 and my engine shakes a little when it warms up an is idling at a red light.(sometimes) changed plugs & fuel filter but now after reading previous posts i beleive it might b the coils. anybody know if this could b the cause(coils).
thanks
Old Jul 4, 2007 | 12:24 AM
nti06's Avatar
Default RE: engine shakes on idle. coils?
quite possible for the coils. a code scan should point you toward a misfiring cylinder.
look for vacuum leaks as well. brittle plastic lines will break if you fart too hard.
Old Jul 4, 2007 | 04:40 AM
kiloslanga's Avatar
thank you.
Old Jul 4, 2007 | 08:26 PM
cap79's Avatar
big possibility, due to mainly valve cover gasket leaking, oil gets into
coils, recomend replacement on both valve covers and all coils, once one coil goes bad the rest follows.
Old Jul 5, 2007 | 12:57 AM
kiloslanga's Avatar
true. i order 8 on ebay for $250. dealer wanted $1000, thanks again .
Old Jul 5, 2007 | 06:52 PM
kiloslanga's Avatar
what would one have to listen for or look for if it were the cat? because i had a feeling it could be the catalyctic but saw oil on coil boots so figured they were fried. will check that though.
Old Jul 5, 2007 | 08:54 PM
jag_genius's Avatar
id fix the cam covers then buy one new coil... then when the cars is all back together and running rough... i usually.. change one coil at a time.. until the car runs good then you know you changed the right coil... then throw away the bad coil...
Old Aug 6, 2007 | 05:06 AM
kiloslanga's Avatar
thanks guys, changed coils and shes running smooth again.
cissdm
May 3, 2016 06:02 AM
Dicque
Sep 19, 2015 12:53 PM
EZDriver
Sep 8, 2015 09:25 AM
Bowman
Sep 3, 2015 03:17 PM
OkieTim
Sep 2, 2015 12:48 PM
