Engine wiring mount
Old Sep 7, 2023 | 04:58 AM
Alexander UA's Avatar
Default Engine wiring mount
The car went with dangling wiring in this place. After removing the lpg
, now I want to restore the fastening of this node, but I don’t know how it should look. I would be grateful if someone share a photo with this mount. Thank you!
Old Sep 7, 2023 | 07:17 AM
Peter_of_Australia's Avatar
I can't help you there for 2 reasons:
I am in Australia, and I just checked: Everything looks totally different on my S-Type, as it is a RHD.
I am sure, yours is a LHD.
Also: My upper alloy air intake looks totally different, so I assume you have totally different S-Type model.
Hence, for anyone to be able to help you, we need to know what model of Jaguar S-Type (Liter? Petrol? Diesel?) exactly and which model-year yours is.
Old Sep 7, 2023 | 08:53 AM
S-Type Owner's Avatar
That is the X200, or pre-initial facelift configuration. Perhaps Karl can help on this as he has a similar model.
Old Sep 7, 2023 | 10:56 AM
clubairth1's Avatar
Community Influencer
Maybe remnants of the LPG conversion they did not remove?
Does the car run OK? Throwing any codes?
Old Sep 7, 2023 | 12:19 PM
JagV8's Avatar
Member joycesjag may have posted photos that would help
Old Sep 7, 2023 | 03:19 PM
kr98664's Avatar
Here’s a picture of the same area on my ‘02 V6:
Sorry, not the best lighting so it’s a bit hard to see all the details. Three connectors are attached to a bracket that stands off from the firewall. Two of the connectors are on the firewall side and the third is by itself on the face of the bracket.
Was that what you needed to know? I couldn’t really tell where the wires go, as it is quite cramped back there.
Old Sep 7, 2023 | 03:33 PM
joycesjag's Avatar
OP's is definitely pre-face lift. My pics won't be any help.
Old Sep 8, 2023 | 07:09 AM
I'm sorry, the picture is just from the Internet, I circled the place that interests me. My s-type 2000 3.0v6
Old Sep 8, 2023 | 07:17 AM
[QUOTE=clubairth1;2676778]Может остатки ГБО конверсии они не убрали?
Машина едет нормально? Кидать какие-нибудь коды?
.There are certain problems with it. I try to solve them as I have free time. The main problem remains, these are strange fuel adjustments and unstable engine operation when connecting oxygen sensors. When they are turned off, the machine operates normally in an open circuit. If anything, they were replaced with new ones, but without changes (It is very difficult to put the equipment in order after a crooked owner and the same “mechanics”.
.[/ЦИТИРОВАТЬ]
Old Sep 8, 2023 | 07:23 AM
I don't have this metal mount(
Old Sep 8, 2023 | 12:31 PM
bydand's Avatar
Not trying to confuse things, but!
These are from a S type 2000 V6 Vin L90540 RHD. On the LHS (left hand side) of the engine bay.
Perhaps have a look at the electrical wiring diagram, for your vin from Gus,s Jag repair web page.
http://www.jagrepair.com/images/Auto...01999.25en.pdf
This should describe where every connection is located.
Flex320
XJ XJ12 ( X305 )
Jan 5, 2023 12:12 PM
Nedoerr
Nov 22, 2022 08:01 AM
kazi
Feb 24, 2020 08:46 AM
Higgins
Feb 20, 2019 05:50 PM
martin fothergill
Mar 19, 2010 09:13 PM
