Need help finding a part
Old Aug 24, 2013 | 03:39 PM
somedude's Avatar
Default Need help finding a part
I need help finding this part, what is it called and what's the part number. It's the hose that's been pointed, seems like the coolant is leaking from the point where hose is connected with the tube.
Old Aug 24, 2013 | 04:27 PM
V40TC's Avatar
what does it conect to?
is is an oil cooler pipe?
power steering pipe?
Old Aug 24, 2013 | 04:39 PM
avt007's Avatar
Post a wider shot, with your year, model, and engine size, then someone can help you better.
Old Aug 24, 2013 | 05:45 PM
somedude's Avatar
It's 2005 stype 3.0.
If I am standing straight to the car looking at the engine, this pipe is located on the right bottom of the tri pipe that runs from coolant reservoir.
Old Aug 24, 2013 | 06:03 PM
It's he QD connector from the DCCV I think I'll have a shufty for a pat number, I think there's an O ring in there.
Old Aug 25, 2013 | 11:11 AM
somedude's Avatar
I have attached 3 more pictures, maybe this would help to point the actual part number.
Attached Thumbnails Need help finding a part-2u6jvpl.jpg   Need help finding a part-2889nqh.jpg   Need help finding a part-30a58jd.jpg
Old Aug 25, 2013 | 03:33 PM
clubairth1's Avatar
Community Influencer
It's one of three heater hoses. At this late date and age you need to replace all the rubber hoses. They will start leaking one by one.
Your car is a 2005 and is now 8+ years old
Be thankful you don't have an STR!! I changed all the hoses on my 2005 STR and there must be 16-19 separate hoses with the inter cooler and all that.
Old Sep 3, 2013 | 01:40 PM
Gus's Avatar
Gus
I have a 2000 S-Type and my connections have not leaked yet. As for your leak that connector has 2 rubber “O” ring that might be giving out on you I would check it first before dealing with the hoses. Chances are you can get replacements at any local hardware store or hyd shop that has a selection to pick from. See photo link.
Link http://www.jagrepair.com/images/Auto...otos/DCCV7.jpg
JarodL
Mar 7, 2024 01:39 AM
way2far
Aug 31, 2022 09:26 AM
hafren
Sep 2, 2015 06:22 PM
innzane
Sep 2, 2015 10:08 AM
TC Johnson
Sep 2, 2015 09:30 AM
