pan kit
Old Feb 4, 2016 | 11:11 AM
Kewpie's Avatar
Default pan kit
I read in the stickies about this kit, people have bought and used it for their cars
New Auto Transmission Oil Filter Pan Repair Kit Fit BMW 6HP19 24117571217 | eBay
The site says that it won't fit a Jaguar Str, but they also said their charts are not accurate.
Before buying, does anyone know if this will fit a 2005 str?
Old Feb 4, 2016 | 11:14 AM
Jon89's Avatar
You need a kit that fits a ZF 6HP26 transmission because that is what you have. The link you posted is for a ZF 6HP19 transmission....
Old Feb 4, 2016 | 11:22 AM
Kewpie's Avatar
thanks
Old Feb 4, 2016 | 11:44 AM
JagV8's Avatar
In case they also do a BMW 6HP26 one, it will likely have a metal pan - which our cars don't have. It may work but I don't recall anyone taking the chance.
Old Feb 5, 2016 | 11:09 AM
Kewpie's Avatar
Will this one work?
New BMW 6HP26 Automatic Transmission Oil Pan Repair Kit with Gasket 24117571227 | eBay
Old Feb 5, 2016 | 12:26 PM
MyBlackCat's Avatar
The CTSC - ZF Parts
This is the place most of us use. comes with the correct fluid in the kit.
Old Feb 5, 2016 | 03:39 PM
Datsports's Avatar
This is the kit I bought on eBay ! It's a steel pan coversion kit also
Comes with hex bolt conversion great idea ! It's only $45 to change the filter next time as you don't have to replace the whole pan each service ! Can get the oil with the kit aswell
But I got mine locally
Ford Territory ZF6HP26 6 Speed Automatic Steel Oil Pan Service Kit | eBay
Old Feb 6, 2016 | 09:43 AM
Jon89's Avatar
Good to know that we have a steel pan option that fits. If we decide to keep our S-Type and XK8 for the long haul, I would be inclined to go this route the next time I decide to do a ZF drain-and-fill on either one of them. My S-Type's original plastic pan is now pushing eleven years old. My wife's XK8's original plastic pan was replaced by Klaus' CTSC kit in July 2013....
Old Feb 14, 2016 | 10:56 AM
maywho's Avatar
I used a 6r80 aluminum deep pan for mustang on my 03 STR worked fine dropped temp (3 qt. more fluid) trans shifts better! I used Mercon SP, did not do a full flush. it does sit 3" lower, could not find a 2" lower did not want to take time to cut and weld. I hit (bottomed) once on a mall speed bump drove over two fast! been fine on highway and in town 3 mo of driving .
Old Feb 14, 2016 | 11:25 AM
clubairth1's Avatar
Community Influencer
You have a temperature gauge for your transmission fluid temperature?
What numbers do you see?
Old Feb 19, 2016 | 04:12 PM
jag79's Avatar
https://www.jaguarforums.com/forum/x...it-sale-44764/
your welcome....
sweatyfox
Feb 10, 2016 10:20 AM
jrb53
Jan 28, 2016 07:04 AM
johndahlheimer
XE ( X760 )
Jan 26, 2016 05:20 PM
Gopi Hira
Jan 25, 2016 11:22 AM
MI-FType
Jan 12, 2016 08:09 PM
