Purge valve location on a 2006?
Old Mar 11, 2014 | 05:09 PM
hollywooddippa's Avatar
Default Purge valve location on a 2006?
I've been trying to track down my "small vapor leak" and have found a lot of blogs but I'm confused on locations. I've got a 2006 that was built in Feb 2006. I'm not sure if that is considered an early 2006 or mid 2006. I know a lot of parts are done by the last five of your VIN (mine 66640). One of the best blogs I found was from this site and it had a picture of the purge valve under the hood and it was cracked. My jag doesn't have the same setup under the hood. Mine has the VVT and his didn't which may be why the purge valve isn't in the same location. He referenced part number XR830786 which according to the Illustrated Parts Breakdown from Jaguar it's good for an 01-06 model with the AJ811242 being for the 07-08.
Any insight on where this purge valve is located for the VVT vehicles would be much appreciated.
I've done all the obvious stuff like swap out gas caps with Jaguar dealer parts. Pulled up the back seat and looked for any signs and did the sniff test. Put it up on the lift and inspected the lines going to the charcoal canister assembly. I'll clear out the engine light and it's rear it's ugly head again in a couple of days.
Old Mar 11, 2014 | 07:11 PM
JagV8's Avatar
VIN breaks are in the Vehicle Spec PDF in the stickies
2006 N52048
2007 N71665
so you're 2006
But sorry I don't know where the valve is in your car.
Old Mar 11, 2014 | 07:16 PM
Thank you sir. That'll get me started.
Old Mar 11, 2014 | 08:16 PM
QuartzSTypeR's Avatar
On my '03 its right next to the master cylinder.
Old Mar 11, 2014 | 09:01 PM
They changed the location starting with the 2006 model. The 2005 has it in the same place as yours. I'm guessing it has something to do with Variable Valve Timing (VVT) not sure why that would matter, but that's the only difference between the 2005 and 2006 under the hood.......I think. Of course they changed the brakes, but that's irrelevant for this situation.
Old Mar 11, 2014 | 10:28 PM
I wonder if they changed the location due to having it fail rather than them adding VVT. VVT isn't really going to take up a lot of engine space . Best bet is to just trace the evap lines.
Old Mar 13, 2014 | 01:18 PM
tbird6's Avatar
Sounds like one of those running changes? The JTIS stops at 2004 for the S Type and I guess you need the 2006 information.
Maybe worth signing up for the Jaguar pay stuff? I think it's called Topix?
Old Feb 7, 2017 | 08:14 AM
Just realized I never sent out my findings. The purge valve is still under the hood of the 2006 and up. It's just not attached to the canister as in the previous models because of the multiple failures of the canisters mentioned by QuartzSTypeR.
You'll hear it ticking and it's up above the left valve cover. Part# XR849660
Old Feb 7, 2017 | 09:25 AM
clubairth1's Avatar
Community Influencer
Can you say where it's located?
Not many 2006-2008 R's were made so we are lacking in repair info.
Old Feb 8, 2017 | 07:15 AM
I wrote "purge valve" I meant to say "vacuum valve".
Old Feb 8, 2017 | 07:29 AM
clubairth1's Avatar
A picture is worth a 1000 words!
That explains it.
Well done.
Boy is your engine clean too.
Had you thought about adding the strut tower covers from the 2003 model?
Cleans up the engine compartment a bit. I added them to my 2005 STR.
Old Feb 8, 2017 | 09:18 AM
The picture is of a 2007 STR, but mine is just as clean :-) My wife laughs at me because I detail the entire car including the engine bay and trunk.
I'll have to look into the strut tower covers.
Old Feb 8, 2017 | 10:56 AM
MyBlackCat's Avatar
How is the gas tank sending unit seal repair going?
Old Feb 8, 2017 | 03:31 PM
​​​​​​​The seal should be at my house on Monday. Shouldn't be too bad to replace. If I run across anything out of the norm I'll post the fix.
Old Feb 8, 2017 | 06:04 PM
Can one of you folks see if your vacuum valve is this loud (see youtube video below). My tank is half full, so I know it does it's self checks when the gas is between 1/4 and 3/4 full. It just seems loud to me. It starts clicking about four minutes after starting a cold motor and about 50 seconds after starting a warm motor.
Thanks for y'alls help.
Old Feb 9, 2017 | 11:23 AM
MyBlackCat's Avatar
From memory, I do think ours also sounds this loud. wife has car 99 percent of time. can check on the weekend when I get a chance.
I remember looking at it and thinking my fuel injectors were loud. exactly in this location.
Not many of us with 06 STR to compare too.
bamforp
Aug 14, 2024 05:36 PM
1100me
Jul 24, 2023 06:10 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
SCMike
Sep 9, 2015 09:30 AM
