Radio Security Code upon Battery Replacement
Old Mar 31, 2015 | 01:39 PM
  #41
danIzvernariu's Avatar
Default HELP Radio Code after digits
Hello PPL!
I need some help regard RADIO CODE after dgt.
I exhange the battery yesterday and now i need to insert SECURITY CODE / Radio.
OK, i mark one wrong.
Second time i dgt well but... nothing happen. The cod number remain on display , no sounds advise, no other display msg. ... i wait about 15 min. ON with the radio and nothing happen, mean...the radio donīt work.
Please could someone tell me what is need to do?
( Jaguar sType 3L 6v Executive 2002)
Thank you all
My board:
Old Mar 31, 2015 | 11:30 PM
  #42
i have the right code
Old Apr 1, 2015 | 11:07 AM
  #43
Collector1's Avatar
Are you sure your code is correct? You might want to call Jag with your VIN and they will give you the code again. If I were you I would disconnect the battery and try it over again. Making sure you enter the correct code. Who knows you might have the number put the incorrect number in by mistake. Sometimes our mind says one thing and out fingers do another. If your radio is bad then you will have to buy a new one on Ebay for about 125-200 and replace it. Make sure the seller kept the VIN number.
Old Apr 1, 2015 | 01:10 PM
  #44
HELLO PPL! 01.04.2015 case solved!
IF do you have the right code key radio and if you make some mistakes like me in dgt insert code you will have this ,essage on radio screen :
CODE - - - - 4 ( or 1,2...10 ...) dosenīt matter this · display.
So , if you insert wrong , it must to wait till system will ask you
(i.e. : )
CODE - - -- 5 (or other number dosenĻt matter!)
insert your code example code 7133
below you have 1-6 keys (ref. my radio model see above pics)
key 1 press seven times to mark 7
key 2 press one times to mark 1
key 3 press 3 times to mark 3
key 4 press 3 times to mark 3
Now press key 5 ...and Radio will be ON.
In my experience i do not need to reset system from bat. -unplug
Old Feb 10, 2016 | 09:50 AM
  #45
petermb's Avatar
Default Help with unlocking required
I have a problem that I hope someone will help me with.
I bought an older jaguar. The security code was lost before I bought it. Someone has tried and the radio is no stating "locked 10". I have the code now but does anyone know how to clear the display for me to enter it?
Old Feb 10, 2016 | 03:47 PM
  #46
Paul792's Avatar
Hi Peter
This link, to a post by Norri, has a radio key program generator.
https://www.jaguarforums.com/forum/s...o-code-147624/
However, you may not need to generate a new key if you now have the correct code. As it states below in the instructions to the key generator program.
"To clear the serial press the seek button on the radio."
You might want to see if pressing seek works on your specific "locked 10 code" before you download the program.
Old Oct 4, 2016 | 01:13 PM
  #47
ttodd's Avatar
Default Radio Code 04 xj Good Job
Originally Posted by Jeff0296
I think pressing A.Mem + PTY + >>. At the same time
Works on my 2004 with sat nav to bypass the code.
Shhhhh it's a secret
Regards
Jeff
Hi Jeff
U saved my *** today. Disconnected battery to change pesky rear shocks and when I was done no radio but your tip worked
THANK U!
Old Nov 2, 2016 | 10:04 AM
  #48
Mekus's Avatar
Default Locked 10
My jaguar S type has this displayed on the radio "locked 10". Does anybody know how to wipe it or open it. Help pls, thanks
Old Mar 5, 2021 | 03:41 AM
  #49
JPB's Avatar
JPB
My experience with S-Type 2006 after a short or long disconnection of the battery is :
- I have to re-enter radio code no matter how long is the disconnection
- the FF + A.MEM + PTY key combination works just fine for me and bypass the code
- My local French Jaguar dealer in Dijon was able to provide radio code easily with a proof of ownership
- There is a side effect on window closing, the trick here (https://www.jaguarforums.com/forum/x...esolved-82236/) works fine.
Many thanks to this forum
TropicCat
Jul 13, 2021 10:51 AM
Adam Lueb
Dec 8, 2015 06:23 PM
jaguarlady03
May 17, 2013 03:09 PM
chazaroo
16
Mar 2, 2013 06:28 AM
baffourg
Feb 27, 2011 08:53 AM
