Random Misfires
Old Jun 20, 2010 | 04:59 PM
uptwobucks's Avatar
Default Random Misfires
2002 Jaguar S-Type 4.0
I have replaced all 8 coils and spark plugs. Cleaned out the air intake, checked for vacuum leaks. No leaks were found. Using the CanOBD2 to read engine codes, I get P0303 code on cylinder #3. I clear the code, drive the car and recheck only to get a P0303 on #2. Cleared the codes again, drove the car and received a "Random Misfires" code.
Any thoughts?
Your help is greatly appreciated.
Old Jun 20, 2010 | 05:02 PM
uptwobucks's Avatar
More information:
The car does not misfire at idle or holding highway speeds.
Old Jun 20, 2010 | 05:40 PM
steve11's Avatar
ud
Something I'm not understanding about your issue. P0303 describes a misfire on Cylinder #3. What do you mean by a P0303 on #2?
Can you tell me what cylinder you went to for #3? and #2?
I might be able to help you if I can fully understand the issue.
Best.
Old Jun 20, 2010 | 05:59 PM
uptwobucks's Avatar
My mistake about P0303 on #2. I gave the wrong code for #2. The problem is that the engine only misfires on acceleration but gives a different cylinder each time. I am in the process of moving the #3 coil to #1 and number one to #3, to see if #3 still misses.
On the 4.0 engine I have the cylinder order as:
Passenger side, front of car to back of engine as 1234
Drivers side, front to back of engine 5678
Is this correct?
Old Jun 20, 2010 | 07:21 PM
test point's Avatar
Jaguar used both A1, A2, . . . B1, B2 . . . and the more standard 1357 /2468 through the years.
Here is the cylinder numbering chart from JTIS for the 4.0:
File Type: pdf
Old Jun 20, 2010 | 07:38 PM
steve11's Avatar
ud
Is this correct?
Yes, you're correct for your MY. You have misfires on the two inner cylinders on the A bank. Check the ignition control module. There are two. One controls the inner two cylinders on one bank, outer two on the other. The second control module the rest.
Old Jun 20, 2010 | 08:58 PM
uptwobucks's Avatar
Ok, After moving coil from misfiring #3 to #1, now the error code has moved to #1. I am assuming I have a new bad coil?
Old Jun 21, 2010 | 08:26 AM
uptwobucks's Avatar
After returning the new coil on #1 and replacing with another new coil the problem was solved. No more misfires. Great power has returned.
I guess the one must always remember, that even though you bought a new part it doesn't necessarily mean the new part is good.
Thanks for your help!
Old May 23, 2016 | 02:44 PM
sosajag's Avatar
Default jagaur s type r misfire
hey i need some hel with my 03 jag s type r i got misfire codes on cylindes 2468 well i went to autozone and try to buy the 4 ignition coil but the guy inside autoz recommended me to first replace the spark plugs which i di but no solutions but when i was replacing the 8 spark plugs i found oild in some holes in like 3 in the driver side and probably two on passenger side so i got told i have valve cover problem wich i believe i don i can see alittle oild coming out of the two valve cover ,,, but i wondering if i fix that could possible fix my problem ,,, cuz i really believe it could be just that cuz the car was runnig good just had cel needed replace 2 drownstream oxygen sensor i did that and light didn go off so i check the computer again and i got 5 or 4 faulty codes p03008
Old May 24, 2016 | 07:14 PM
NBCat's Avatar
Firstly, please write clearly so you can be understood.
If I understand you correctly, you found oil fouling the spark plugs and coil units on Bank2. In that case, you must replace the cam cover gasket and spark plug boss seals, then clean the coil units and see if they are still serviceable.
If the MIL is on, what code(s) are stored in the system? DTCs are alpha-numeric with five places, so P03008 is not a correct code. Is the DTC P0300 or P0308? Replacing oxygen sensors is not going to correct a misfire.
Old May 24, 2016 | 08:10 PM
sosajag's Avatar
Default 2003 jaguar s type r misfire codes
i have jaguar type r misfire codes on cylinder 2 4 6 8 so i replace cylinder 2 and 4 cuz i couldn't find the other 2 i ordered so i drove the car and i can feel better now still shaking but have and give more power so i went back to auto zone hoping some code may be cleared but no i got more misfire codes now they suggested me to replace the whole 8 coils that sounds stupid and weird to me ,, don't know what should i do now i thinking to replace the other 2 and see whats going on still got the cel and the restricted performance message ,,, any reply ir advise will help,,, well here the codes i got today p0301 ,p0302 p0303 p0304 p0305 p0306 p0307 p0308 and p1316 p1474 p1647
Old May 24, 2016 | 10:39 PM
NBCat's Avatar
Do not operate the vehicle under conditions that cause the MIL to flash as catalyst damage is occurring.
Check the wiring loom to the fuel injectors and check the fuel pressure at the Schrader valve. Post the fuel pressure readings here.
Also, what is the age and condition of the battery? A failing or weak battery that has 12.2 volts, or less, with the ignition in the off position must be replaced as it can cause many of the electrical faults posted on this forum.
Old May 24, 2016 | 10:47 PM
sosajag's Avatar
i believe the battery is very old , I'm starting to believe battery might be weak cuz when i got the car 1 month everything was perfect it was runnig good only have cel for 2 oxygen sensors which i replaced already and i don't have that codes any more only misfire codes now I'm going to try a new battery possible or try with other battery thanks for your advice i`ll post back when i get results
Old May 25, 2016 | 08:55 AM
clubairth1's Avatar
Community Influencer
Your big question is have you changed the timing chains and tensioners on your 4.0L?
You are on borrowed time if they have not been changed.
Old May 25, 2016 | 08:59 AM
NBCat's Avatar
You are on borrowed time if they have not been changed...
I believe sosajag has an S-Type R with the 4.2 litre unit.
Old May 25, 2016 | 09:24 AM
JagV8's Avatar
The posts are SO HARD to read.
Please use punctuation.
Old May 25, 2016 | 07:30 PM
abonano's Avatar
My thoughts exactly!
Old May 26, 2016 | 06:37 AM
clubairth1's Avatar
Sorry you are right! I was trying to respond to the original guy who had the 4.0L.
aode06
Jul 28, 2023 02:26 PM
kingdom worker
Nov 14, 2020 03:47 PM
pnwrs2000
Nov 17, 2015 04:04 AM
reb1999
Sep 26, 2015 08:41 AM
