Rear vents on console not working
Old Dec 8, 2012 | 05:49 PM
Henry's Avatar
Default Rear vents on console not working
I have a 2001 s-type and just realized that the vents on the end of the center console facing the back seats are not working at all. All other vents are working fine. Any suggestions would be much appreciated.
Thanks,
Henry
Old Dec 8, 2012 | 06:47 PM
abonano's Avatar
Did you try the "floor setting" on the HVAC panel - be advised the rear console vents really don't blow out to well. Another possibility - the vent hose going through the console might be disconnected at the rear vents in the console - especially evident if the console was removed to service the shifter perviously.
Old Dec 8, 2012 | 07:30 PM
Henry's Avatar
Abonano,
I will give it a try and get back with you. Thanks again for your help.
Henry
Old Dec 9, 2012 | 07:30 AM
93XJR-S's Avatar
Default RE vents
I had a similar issue was cure by replacing the servo thing for the vents and replacing the foam gaskets throughout the ac system, they had all deteriorated to dust
Old Dec 9, 2012 | 07:31 AM
Brutal's Avatar
floor doesnt work for rear vents. if theres no disconnection in the console youll need to close down the center dash vents to increase air flow to the rear. Its nothing more than the path of least resistance. The center dash vents have to be almost closed or closed to really increase the airflow
Old Dec 9, 2012 | 09:06 AM
Henry's Avatar
I will give this a try and let you know.
Thanks Brutal
Old Dec 29, 2012 | 12:39 PM
Henry's Avatar
I did check the vents and they are connected. I shut down the dash vents and did receive a little bit of air flow. I guess this will have to work for now.
Thanks for the information
Henry
Old Dec 29, 2012 | 04:46 PM
SchultzLD's Avatar
Mine was simply the flap for the vent was disconnected. (probably the kids messing with the vent too much...) Took the rear vent cover off, popped it into place, and works fine now.
johnnie ryall
Oct 19, 2015 09:44 PM
jrbong
Sep 3, 2015 12:54 PM
XFR_Gold
UK & Eire
Sep 2, 2015 06:30 AM
peterg19
Aug 30, 2015 08:48 AM
Jandreu
Aug 29, 2015 07:31 PM
