S type fuel pressure
Old Apr 16, 2018 | 09:09 PM
dbjenks's Avatar
Default S type fuel pressure
i am showing 32 on fuel guage at idle on my 2000 jag type s 3.0. What should the pressure be at idle? And does this model have a fuel pressure regulator?
Old Apr 16, 2018 | 10:39 PM
abonano's Avatar
Over 40 psi at idle and yes. When was the fuel filter changed out last?
Old Apr 17, 2018 | 06:44 AM
dbjenks's Avatar
It has a new fuel pump and filter. It runs perfect and idles perfect but sometimes it will just die at idle and then restart. I also put a new crankshaft sensor on. Where is the fuel regulator located and what does it look like. This is a 6 cylinder.
Old Apr 17, 2018 | 11:57 AM
NBCat's Avatar
What is the voltage at the fuel pump connectors?
X200 fuel system specifications below:
Attached Thumbnails S type fuel pressure-x200_fuel_system_specifications.jpg
Old Jan 24, 2025 | 02:36 PM
JeffFaith's Avatar
Default Fuel pressure doesn't change during acceleration
Hello,
I was checking mine as I was getting a lean code and my Fuel Pressure was at 378 kPa at Idle and barely changed with acceleration Manifold pressure was 39kPa, both LT Fuel trims are high at Idle 14% and 17% at idle and then drop quickly with acceleration.
Changed the air filter and MAF was ok for about a week before light came back on.
Old Jan 24, 2025 | 03:48 PM
JagV8's Avatar
Sounds like a classic air leak but do you have codes? N.B. they only flag after occurring twice (like many codes).
Old Jan 24, 2025 | 03:52 PM
JeffFaith's Avatar
P0171 and occasionally I get a p0174 but its rare, usually just the P0171
The air filter was terrible and seemed like it hadn't been replaced but it was supposed to have been, I cleaned the MAF and it at first seemed to help but then stopped so I replaced it with a Walker. Then had both codes and saw the MAF was loose so I tightened it and it seemed to be fine for a week or so
Old Jan 24, 2025 | 03:53 PM
JeffFaith's Avatar
Old Jan 24, 2025 | 03:54 PM
JagV8's Avatar
If the trims drop on revving it's pretty much got to be one or more air leaks.
Old Jan 24, 2025 | 05:00 PM
JeffFaith's Avatar
It threw me off at first, when I first swapped out the MAF, the LTFT were both at 6.25 at idle, then when I got the car warmed up they jumped to 16.78 and 14.45 at idle
iconic
Jun 1, 2016 11:44 AM
75Gremlin
Sep 25, 2014 07:27 PM
hdsg
Jan 6, 2014 04:04 PM
Skid Mark
Feb 5, 2013 10:22 PM
Spurlee
Mar 26, 2011 06:23 PM
