Two fault codes I've never had before
Old Dec 17, 2024 | 02:52 AM
Darrol2004's Avatar
Default Two fault codes I've never had before
Hello everyone
marry ChristmChristmas
all my jaguars had been going great
until yesterday
Driving along in my 2004 4.2 N/A right hand drive
had no problem with engine since I rebuilt it 12 Months ago
Then I received on Instrument cluster gear box fault
Stoped car tuned off
then started car no warning lights
went on my way no problems
when I got home I used my icarsoft cr pro scanner
And brought up two codes
P1396 variable valve timing solenoid 2 Malfunction
not sure if left or right bank
I do have spear solenoids
P0706 transmission range sensor circuit range/performance
Any help would be greatly appreciated
As hope to take this car away at Christmas
Thanking you
Darrol
Old Dec 18, 2024 | 08:39 AM
motorcarman's Avatar
P1396
VVT solenoid valve 2 to ECM PWM drive
circuit fault
VVT solenoid valve 2 ground circuit fault
VVT solenoid 2 failure
Oil contamination
VVT 2 oil flow fault
VVT / camshaft mechanical failure – bank 2
P0706
J Gate selector position
plausibility fault
TCM / J Gate Module CAN fault
J Gate Module failure
TCM / Control valve failure
Old Dec 18, 2024 | 11:51 AM
NBCat's Avatar
What is the available battery voltage with the ignition in the off position for half an hour? Use a voltmeter across the battery terminals to read the voltage. The vehicle needs at least 12.6 volts available for all modules to function correctly.
Random DTCs and instrument cluster warnings are often caused by low available voltage.
Old Dec 18, 2024 | 02:17 PM
JagV8's Avatar
P0706 - could it be a loose/missing bolt that's meant to hold the shift cable to the trans side? Should be two 8mm hex headed bolts (under car). Quite often come loose or even fall out.
Old Dec 18, 2024 | 02:31 PM
kr98664's Avatar
More details here:
https://www.jaguarforums.com/forum/s...l-bolt-269294/
Old Dec 21, 2024 | 01:56 AM
Darrol2004's Avatar
Found problem vtt solenoid had broken wire
under j gate one of the contacts had fallen out
Old Dec 21, 2024 | 02:05 AM
Darrol2004's Avatar
Thanks this was the problem
Swapped over to my spare no codes now
Old Dec 21, 2024 | 02:07 AM
Darrol2004's Avatar
Originally Posted by kr98664
Thanks found the problem
baguafit
Aug 30, 2022 04:09 PM
7XKR
Apr 30, 2020 10:25 PM
newtojags
Apr 5, 2018 05:55 AM
larueb
Jun 1, 2015 07:05 PM
04Sport
Apr 26, 2015 07:25 AM
