Will not go into D unless it is put into 3 or 2 first
Old May 30, 2011 | 01:48 AM
peruano4life's Avatar
Cool Will not go into D unless it is put into 3 or 2 first
2000 S-type 8 cylinder
My car has a problem getting into "D" you have to put it into a lower gear first then you can put it right into D without any problems. I am not a mechanic or anything close to it.
At first I thought it was a transmission problem but as soon as you put it in D weather it the car was moving or not it will drive fine. Meaning if I just get to the car and start it up and put it in 3 first then into D --without-- moving the car the car will operate normally. So my conclusion is that it's not the transmission because it would not go into 1st gear at all if it was, but again I am not a mechanic so I might be shooting in the dark here.
I wonder if I am the only one with this problem or if there is someone else out there with something similar
thank you to anyone who can help me with this
Old May 30, 2011 | 03:19 AM
JagV8's Avatar
Search on terms like
shifter
5R55N
Not uncommon with early cars (V6 as well as V8). Make sure it's fixed soon before you're stranded.
It's almost for sure the shifter etc mechanism. Could be awkward DIY.
Old May 30, 2011 | 06:54 AM
joycesjag's Avatar
This may help:https://www.jaguarforums.com/forum/s...ngaging-52930/
Old May 30, 2011 | 08:54 AM
motorcarman's Avatar
You probably need a revised selector lever cable assy.
See the attached TSBs
bob gauff
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
mrplow58
Jan 21, 2024 05:53 AM
Bcrary3
Feb 21, 2023 04:29 AM
kevinl
Oct 31, 2019 06:15 PM
